First time to the track.
Old Sep 17, 2011 | 01:12 AM
ebeard's Avatar
Default First time to the track.
I've had my car for two years and it's been down most of that time. It's finally running good so I decided to head down to the local 8th mile. This was my first time on a drag strip so i'm sure there is more in it.
CC503 cam, crappy edlebrock headers / exhaust (leaking) (catted), 245 street tires, M6
First run,
2.17 60', 9.05 @ 80.5
Fastest run
2.16 60', 9.00 @ 80.9
I'm hooked lol. I'm gonna get rid of the catback this week and go to a bullet dumped before the axle and fix the leaky y pipe. I think the clutch might be slipping some on up-shifts, could be my imagination though...
Old Sep 17, 2011 | 01:32 AM
Zlow28's Avatar
get some tires and lca and relocation brackets, thatll lower your 60
Old Sep 17, 2011 | 06:23 AM
TravisMcGill2000's Avatar
Yea there's alot more in it. Drag racing is a very addictive hobby. How hard are you turning it? Also what track was you at.
Old Sep 17, 2011 | 07:46 AM
trilkb's Avatar
I would consider a cut out befor dumping and a bullet. The bullet will be loud, droany and stinky. If its a street car a simple 30-40$ manual cutout will help, and you can cap it and drive home at a reasonable tone lol.
2.1 60 out of an m6 with street tires, not bad at all. Good luck to you.
Old Sep 17, 2011 | 09:34 AM
joelster's Avatar
My friend was just at our local 1/8th with his auto car running 8.5's at 78-79mph with a 1.90 60'. Based on your mph, you should be running ET's very similar to his. It's hard to be real consistent with an M6 car.
Old Sep 17, 2011 | 10:20 AM
ebeard's Avatar
Union hill/Music city raceway. North of nashville. I think I was shifting around 6k
I'll still keep the catback. I'm just gonna make a bullet set up that bolts to the Y. I'll be able to interchange the two.
The problem I have with a cut out is that the cat is bolted in rights off the Y so I don't have and room for it before the cat.
Old Sep 17, 2011 | 10:35 AM
96TransAmboosted's Avatar
My car stock ran 9.0 you should be in the low 8 with that cam. I would try 18psi in the tires and feather the clutch a little. Im sure wheel hope and being your first time did not help any.
Old Sep 17, 2011 | 11:29 AM
ebeard's Avatar
Happen to remember the MPH?
Old Sep 17, 2011 | 03:13 PM
93 LT1 Vette's Avatar
DR's will shave some serious time off your E.T's. I'd look for 1.9's maybe high 1.8's 60' and over 1/2 second reduction in the 1/8 mile. I'd say 8.48 at 83 mph.
Old Sep 17, 2011 | 03:57 PM
Badazz 97 TA's Avatar
not bad i guess for first time, could be better. I dont know the elevation or temp so im not gonna be the "oh my car ran this and that when it was stock BS" like everyone does on this site, but it should of ran quicker then that i assume.
Old Sep 17, 2011 | 04:35 PM
My car ran 9.0 stock at sea level in florida on a very humid 100 degree day with full weight and balled street tires. @79mph average.60 foot was almost always a 1.88-90. Automatic car as well. Tl
Old Sep 18, 2011 | 12:46 AM
ebeard's Avatar
Even though it was the first time ,I feel like it should have trapped a little higher. There is an exhaust leak close to an 02, I know that can throw it off.
I don't know what the DA was. But it was a cool night here in nashville, 60ish. Were not far above sea level.
Old Sep 18, 2011 | 01:03 AM
ebeard's Avatar
http://www.youtube.com/watch?v=X2vQYnpKvGc
Old Sep 18, 2011 | 02:15 AM
whytryz28's Avatar
Ran this with just, Lid, shorties, cat-back and tune. (Left lane)
60' is almost as bad as yours, get some better tires. Your trap speed is good for the time you ran, you have more in it.
Old Sep 18, 2011 | 07:51 AM
bufmatmuslepants's Avatar
you need a tune brotha! 80MPH is WAY low, should be at least 85 with a tune and fast shifting. Are you powershifting?
Old Sep 18, 2011 | 09:10 AM
lt1-xjs's Avatar
You certainly have a lot left in that car. The exhaust leak doesn't help and neither does the low rpm shift. It takes practice.
I have a few bolt-ons and my car has run a 8.13 @ 84 and weighs 400# more. The 503 should put you in the 12.0x range, a 7.7 to 7.8 1/8. It just takes time to get there.
Old Sep 18, 2011 | 10:11 PM
ebeard's Avatar
Yeah the exhaust is fixed. Going again friday, gonna try to dial in the shift points and see what happens
Old Sep 18, 2011 | 10:20 PM
ebeard's Avatar
It's tuned. But i had to put a cat in there to pass smog, it's tuned for no cat. idk how much of a difference it makes but it cant help. If you mean not letting off the gas pedal, then no, not powershifting. Shifts are fast though.
Old Sep 19, 2011 | 12:12 AM
IronOutlaw's Avatar
What RPMs are you shifting at? Maybe you are shifting too soon?
Old Sep 22, 2011 | 09:18 AM
on1wheel01's Avatar
Not to bad I dont think. Im hoping to be in the mid 8's when I finally take her to the track
