1.6 rr ?
Old Sep 20, 2011 | 11:27 PM
93z28de's Avatar
Default 1.6 rr ?
ok what kinda issues have ppl run in to when puting 1.6 roller rocker arms on
Old Sep 21, 2011 | 06:16 AM
RamAir95TA's Avatar
None if it's done correctly.
Seriously, you have to trim the OEM valve covers for clearance (on most brands of rockers) and you NEED to change the valve springs. Other than that it's a pretty straight swap.
There is a lot of things to screw up if you don't know what you're doing though.
Old Sep 21, 2011 | 07:27 AM
tbag_skywalker's Avatar
What RamAir95TA said. Piece of cake swap, trim the inside of your valve covers with a dremel or a pair of tin snips. Swap in a good set of valve springs while the rocker arms are off since the stockers are junk.
Only issue I ran into with the valve spring swap was finding a compressor that works on double springs in tight spaces.
I rented a KD tool to get the stock springs off, then bought a cheap 'lever type tool' to install the front 8 springs, then made my own 'Tim's tool' to do do the back 8 springs under the windshield.
Old Sep 21, 2011 | 09:10 AM
BlackScreaminMachine's Avatar
Internet Mechanic
GMPP 1.6 SA's do NOT require any modification to the valve cover as I had a set of those. But anything beyond that, say a Pro Mag did need modification to fit.
I always recommend swapping springs, even be it slight improvement, its better for valve control. We had a local kid not swapping springs over and never an issue but no need to push your luck.
Old Sep 21, 2011 | 07:39 PM
93z28de's Avatar
Default ok
ok thank's for the info. next ? how dose the car act its a nice car its fast now put i just want to do small stuff nothing big
Old Sep 21, 2011 | 07:56 PM
GR33N GoblinM6's Avatar
My Skip White 1.6 SA rr fit very well under stock valve covers
Old Sep 21, 2011 | 09:34 PM
Assuming you install them right and set the lash correctly, your car will run exactly how it does now, drivability won't change.
The roller rockers are a bit noisier than the stock arms-- if you open the hood while the cars idling, they sort of sound like a "sewing machine" in the back ground. Not obnoxiously loud, atleast my Pro-Mags aren't.
You'll see a small gain in power, 10-15ish, especially up top if you swap in good valve springs, too.
Old Sep 24, 2011 | 08:38 PM
93z28de's Avatar
Default ok
ok well how dose a52mm bbk act and underdrive pullys and chip
and i would like to know is it worth swaping to a obd 2 setup or 94 up
Old Sep 25, 2011 | 12:31 PM
FAD2BLK93's Avatar
I use the 96 lt4 rollers and the stock springs for 4 years now, and go to the track. Have never had a problem direct swap although i should replace the springs (186k). I saw 2 tenths or 20 horse improvement over stock. I dont think i will ever convert from the speed density setup!
Old Sep 25, 2011 | 12:55 PM
bowtienut's Avatar
Generic "chip": NO. A custom tune: Yes.
52mm TB will help if you have a free flowing exhaust and intake, but it's not worth much. No noticeable difference on a stock vehicle.
U/D pulley: maybe 2hp. It has an advantage of slowing down the accessories though if you have a high revving built engine or if you road race it.
OBD 2: I have no idea why you would want to do that. I converted mine from OBD2 to OBD1 just for ease of tuning (much cheaper software at the time). All B-bodies had Mass Air, whether OBD 1 or 2.
Mass Air is nice, but I wouldn't bother with it if the car wasn't already set up with it. Is that why you're thinking OBD2?
Old Sep 25, 2011 | 08:07 PM
93z28de's Avatar
Default ok
FAD2BLK93 how many miles didnt you car have when you didnt that. bowtienut and i have cold air intake and and 3' out the back so i think the 52mm bbk would help alot and how is going from a obd2 two obd1 better for tuning i use to have a 02 firehawk i had hp tuners
Old Sep 27, 2011 | 03:07 PM
FAD2BLK93's Avatar
I got this car with 122k on the odo and now it has 186k no problems. It seems when designers went to obd2 the made things more complicated with more variables to tune...i stay away from handheld tuners and have pcmforless do mine, they are first rate never an issue. Long live OBD 1.
Old Sep 30, 2011 | 08:29 PM
93z28de's Avatar
stuped ? dose the pvc have the little ball in it
Old Sep 30, 2011 | 08:52 PM
defaultexistence's Avatar
Are you drunk posting again?
Old Oct 1, 2011 | 09:25 AM
Underdrive pulleys do almost nothing, and a 52mm throttle body will only give you a few horsepower on a stock motor-- not worth the $300 to me unless its going on with a new cam, or all the rest of the basic bolt-ons have already been done.
Roller rockers and valve springs will give you more power than a bigger throttle body and underdrive pulleys. Pair that up with headers and a custom tune and you'll have a noticeably quicker car.
Old Oct 1, 2011 | 09:31 PM
93z28de's Avatar
Default ok
well i had a 52 mm bbk for 150 bucks but i was to slow geting there o well so i guess ill do a chip and roller rockers
Old Oct 1, 2011 | 09:41 PM
93z28de's Avatar
Default ok
