head gasket for boost
Old Sep 25, 2011 | 07:10 AM
boostedlt1's Avatar
Default head gasket for boost
what is a good head gasket to run on a boosted car.
~8.5:1 compression, eventually will see 12psi.
gm, fel-pro, cometic, etc...
discuss!
Old Sep 25, 2011 | 10:23 AM
97Z28SS's Avatar
Any MLS gasket, I personally use Cometic on all of my engines regardless.
Old Sep 25, 2011 | 11:20 AM
merim123's Avatar
or fel-pro 1074.
Old Sep 25, 2011 | 11:49 AM
pro94lt's Avatar
1074's are what i've been running with around 12psi and 9:1 cr
Old Sep 25, 2011 | 11:51 AM
pro94lt's Avatar
The reason, is their at almost any parts store, have a proven record of being a good gasket, are cheap and conform to blocks and heads that may or may not be perfectly flat... Those are all things I look for in any part.
Old Sep 25, 2011 | 12:14 PM
boostedlt1's Avatar
Thanks for the responses, always nice to have real world experience
Another question, arp head bolts. Do you guys torque them to spec, or add a couple pounds for boosted apps?
Old Sep 25, 2011 | 08:18 PM
Ponyhntr's Avatar
Fel Pro 1074, torque to specs. I ran these last year on 19psi on pump gas. I ended up hurting the motor with bad gas, but the head gaskets were just fine.
Old Sep 26, 2011 | 11:00 AM
boostedlt1's Avatar
damn i wanna run those but i dont want my compression to be that high
i guess if it turns out my le2 heads are fucked and i have to throw my stockers back on it'll be fine, or i'll just turn down the boost a tad
Old Oct 3, 2011 | 07:55 PM
boostedlt1's Avatar
1074's go on tomorrow!!
these are the piece of **** 9966pt's the machine shop gave me to run...
almost lost cylinder #2 and 8 as well
Old Oct 3, 2011 | 07:58 PM
Sc0tt30's Avatar
Any reason you choose the 1074 over the Cometic? I am needing to make the same decision eventually.
Old Oct 4, 2011 | 02:12 AM
boostedlt1's Avatar
just cause they're easy to get and read a lot of good reviews on them. its my DD so i didn't have time to wait around to get a set of cometics shipped to me.
also after calculating everything i'll be at 9.4:1 compression with these. in my original post i meant to say 9:1, idk where i got 8.5 from... haha
i decided i wanted a little bit more compression, my fuel system cant handle "full boost" yet so i believe 9.4 will be a better compression ratio for the mean time
