back firing
Old Sep 25, 2011 | 11:14 PM
ThorsLT1's Avatar
Default back firing
so i just replaced my opti, plugs, and wires and now my car is back firing. it seems to idle ok but misses every once in awhile. back fires whenever you give it throttle.
plugs are gapped at .040
no ses light but i have an lt4 knock module
Old Sep 26, 2011 | 06:19 PM
96SilverZ's Avatar
I believe the plugs are supposed to be gaped at .050 which could cause your problem.
Old Sep 26, 2011 | 06:25 PM
RamAir95TA's Avatar
An .040" gap won't cause your problems. Since you just did plugs/wires, I'd start looking for any loose connections right off the bat.
Old Sep 26, 2011 | 07:30 PM
96TransAmboosted's Avatar
Ramair nailed it. I would think a wire or plug is loose. Or even crossed
Old Sep 26, 2011 | 07:54 PM
defaultexistence's Avatar
Eeyeahhhpp...(spits)
Old Sep 27, 2011 | 07:47 PM
ThorsLT1's Avatar
well it turns out i crossed plugs 5 and 7... doh! and correct me if im wrong but if you have higher compression dont you want less of a gap? my heads have 55cc chambers...
Old Sep 27, 2011 | 08:23 PM
nitrous2fast's Avatar
Only if the motor has fits with a larger gap. Lol
Old Sep 27, 2011 | 10:06 PM
Common mistake when doing plugs in a tight area. .40 will be fine.
