Puzzling LT1 problem
Posting this from my phone so please excuse grammatical errors I have a problem which is completely sporatic where my car seems to be cutting out. And as it does it my gauges both rpm and speedo drop in sync with the stutter,as well as my service engine light flashing in tune with it but not staying on. Now if I shut off the car and turn the key forward my fuel pump will prime in sync with the service light flashing. And it wont stop....its like im turning the key on and off. I was thinking opti but it pulses with just the key turned, so I'm guessing the cutting out is with the fuel pump cutting out. Also the "low trac" flashes in tune with the above mentioned problems. 93 LT1, 6 speed thanks and sorry for the wall of text. Thanks
I know shbox already chimed in on here but his write up on how to change the ignition switch talks about that exact problem: http://shbox.com/ignsw/ign_switch_repl.html
My gauges would drop in sync and almost appear possessed. Occassionally the car would shut off. Replaced the ignition switch and cured the problems.
