Motor torn down !!
Old Sep 26, 2011 | 06:57 PM
Luke1996ta's Avatar
Default Motor torn down !!
Well I took my motor out the top wasent that bad it took me pry three hours worse part was getting the clutch fork out but I took the motor apart and had two main barrings spun so gonna do a complete rebuild what do u guys recomend doing to it as far as getting a new crank or turn the one ?? And line bore or bore the cylinders or horn the pistons and rods looked very good new rings or replace pistons and all
Old Sep 26, 2011 | 07:10 PM
andrew ws6's Avatar
Whats your budget?
Old Sep 26, 2011 | 07:18 PM
defaultexistence's Avatar
^^^ and what dO u Wana dO with it? Line bore mains and new cam bearings will be nessisary . If u are sticking stock cubes turn the crank get some forged rods and pistons and custom grind cam then if u Wana spray it later your protected
Old Sep 26, 2011 | 07:29 PM
Luke1996ta's Avatar
I don't have a set budget just wanna do it right but don't want to spend a lot I just put 1600 it heads and cam
Old Sep 26, 2011 | 07:36 PM
Refer to post #3 minus the questions then
Old Sep 26, 2011 | 08:59 PM
96capricemgr's Avatar
How bad did the mains spin? If the spun bad the block is likely not worth messing with, meaning you need a junkyard engine to start with.
Old Sep 28, 2011 | 11:53 AM
Luke1996ta's Avatar
It didnt spin bad but it spun if u get that haha
Old Oct 1, 2011 | 05:14 PM
Luke1996ta's Avatar
Who makes good forged rods and pistons for the money or what are u guys running
Old Oct 1, 2011 | 05:30 PM
IronOutlaw's Avatar
Im going to be using 6" Scat Pro Comp rods and Mahle Powerpak Pistons. Ive heard of a lot of guys running this setup with great results. If you are going to spray a lot of Nitrous you may want to go with a different piston though.
Old Oct 1, 2011 | 05:39 PM
Luke1996ta's Avatar
Well I'm not gonna spray anytime soon maybe down the road but maybe like a 75 shot that's y I want to build it for later down the road but I want good results
Old Oct 1, 2011 | 05:53 PM
IronOutlaw's Avatar
Im gonna spray a 100-150 shot. The mahles will handle a 75 easy.
Old Oct 1, 2011 | 06:16 PM
Luke1996ta's Avatar
do u have part numbers and what compression do u have i have stock heads that are ported and a cc502218/224 @.050/495/503 cam ya small cam i will go bigger lol or want to. I have to get my block line bored since i spun barings so they will pry want bore it over .30 which wouldnt be a bad lol
