Pulling engine...HELP!!
Old Sep 26, 2011 | 09:44 PM
azlt's Avatar
Default Pulling engine...HELP!!
Pulling my motor for a rebuild, EVERYTHING is disconnected, wires, exhaust, motor mounts are off, ect, ect.
All 6 of the bellhousing to motor bolts are removed and the car is an m6 so there shouldnt be anything else holding it on, I CAN NOT break the thing loose from the tranny, no matter which way i raise, lower or yank it, I am doing the pull from the top, and i already wish i went the out the bottom route..
Im too far into this to turn back now, been at it for two days, the thing is hooked to my cherry picker right now.
ANY idea you guys have on how to get this thing out?
thanks.
Old Sep 26, 2011 | 10:41 PM
shbox's Avatar
Just about anyone that cannot separate the engine from a manual tranny has not pulled the clutch release fork from the throwout bearing.
Old Sep 26, 2011 | 11:29 PM
azlt's Avatar
how is that done?? I hate this hanes manual.
Old Sep 26, 2011 | 11:55 PM
Catmaigne's Avatar
You grab the fork and pull it out after removing the slave. It's that easy.
Old Sep 27, 2011 | 12:46 AM
azlt's Avatar
i knew that thing had to do with removing it, wow i couldove had this done in an hour if i knew this! Thank you so much guys!! you just taught a kid how to remove an engine!
Old Sep 27, 2011 | 04:52 AM
camar0corey's Avatar
It's a common mistake.
Old Sep 27, 2011 | 05:00 PM
Slow94Formula's Avatar
Same thing happened last weekend when mine was getting taken out... spent an extra half hour trying to figure out why it wouldn't come forward.
