cps reluctor wheel?
Old Sep 27, 2011 | 02:27 PM
lt1camaro383's Avatar
Default cps reluctor wheel?
I've seen to lost my crank key through out the build and now i see it is a cut back crank key. http://shbox.com/1/engine_front_diagram.jpg
My question is will a regular key way work that isn't cut back?
Old Sep 27, 2011 | 02:53 PM
shbox's Avatar
If it is going on an LT1, it has to be cut back to clear the hub, which has no slot for the key. Your could modify one with a grinder.
Short answer: No.
Old Sep 28, 2011 | 12:20 PM
Thanks man where's the best place to get the cut back key? Its 4 a 97 by the way.
Old Sep 28, 2011 | 02:09 PM
shbox's Avatar
...from your favorite GM parts source.
93-95 gm part # 10128303
96-97 gm part # 12550096
Old Apr 12, 2012 | 08:43 PM
BLKtA910's Avatar
I have a problem. I'm throwing a P0336 code and I did my timing chain a few months ago. The car is a 96 TA; it's had the P0336 code, misfires, O2 codes, and runs like crap. My dad works at Jeff Gordan Chevy and said I might have put the relutor plate on wrong. What do you think? Let me know I'm stomped.
