Which of these hoses is NOT for the cooling? (pic)
Old Sep 28, 2011 | 10:22 AM
Rob94hawk's Avatar
Default Which of these hoses is NOT for the cooling? (pic)
The EGR and Air pump are gone. Plan on putting the pump and radiator as soon as it stops raining here. I know the middle hose if for the heater but is the right piping for the Air pump? And the two small lower hoses on the left I just don't remember. Thanx
Old Sep 28, 2011 | 10:29 AM
draggin97s10's Avatar
the short one with the silver heat stuff on it, its the vac hose from the intake to the break booster
Old Sep 28, 2011 | 10:35 AM
RamAir95TA's Avatar
The one on the far right is for the AIR pump.
Old Sep 28, 2011 | 10:47 AM
haha... didnt even notice that. Havent seen one in a long time.
Old Sep 28, 2011 | 10:55 AM
Rob94hawk's Avatar
Ah, I think I'll be needing that. lol
That's what I thought. Just wanted to be sure.
Now I just have to find a home for that little hose on the top left and I should be all set.
Set until I make an attempt to find out where everything plugs into on the wire harness.......
Old Sep 28, 2011 | 11:44 AM
Badazz 97 TA's Avatar
the one on the top left almost looks like a transmission cooler line. Not sure, but that is the only thing that comes to mind right now
Old Sep 28, 2011 | 11:48 AM
airfix's Avatar
The harness part should be easy, every plug is different.
Old Sep 28, 2011 | 12:08 PM
shbox's Avatar
Top left looks like the hose from the radiator to the remote reservoir (under the battery).
Wire harness.
Old Sep 28, 2011 | 12:45 PM
96TransAmboosted's Avatar
Im pretty sure the top left is radiator over flow. It does not have threaded fitting on it for the trans.
Old Sep 28, 2011 | 01:31 PM
Catmaigne's Avatar
Top left is coolant reservoir
Bottom left looks like the brake booster
Far right is for the AIR pump
