Check Gauge Question
Old Sep 29, 2011 | 10:50 AM
Juicelt1z28's Avatar
Default Check Gauge Question
Hi, I'm pretty new to the fbody world,just brought a 96 Camaro z28 a few months ago,recently in the past few weeks my check gauge light will pop up and my temperature gauge shoots up to 260 degrees then goes back to normal maybe a minute later,this mainly happens when I first start driving the car,anyone else experience this issue or have any idea what it could be? Any help is appreciated
Thanks
Old Sep 29, 2011 | 11:25 AM
Zlow28's Avatar
does the car overheat at all? If so, does it overheat while driving or when idling? Mine used to do the same thing when my thermostat was stuck. But first id suggest checking for coolant levels. Also bleed the coolant properly.
Also since ive got the same year as you, try to get access to a water temp gauge to find out your true reading. The needle on my car is way off.
Old Sep 29, 2011 | 11:43 AM
No its not really overheating,it just randomly shoots up to 260 then goes right back to normal a minute or 2 later,but I will definetly check coolant levels and I'm just gonna replace the thermostat anyway
Old Sep 30, 2011 | 01:38 PM
Is replacing the tstat easy to replace?
Old Sep 30, 2011 | 01:45 PM
Zlow28's Avatar
yes its very easy. Look in shboxs website to find out how. all you have to do is remove the air intake and place towels or rags to protect the opti cus coolant will spill.
Old Sep 30, 2011 | 09:47 PM
Ok thanks again,I'm going to let the car cool over night and then check them in the morning
