Ignition timing for cruising?
Old Sep 29, 2011 | 11:20 AM
kgkern01's Avatar
Default Ignition timing for cruising?
I was reading somewhere online that gasoline likes timing for highway cruising in the 41-44 range for best efficiency (and 37-38 for E85). Can anyone else confirm this? The reason that I am asking is looking over my tune and my Datamaster scans, I saw that I am running 29-30 timing while highway cruising around 43-49kPa and 60-66 mph, and I thought that seemed a little on the low side.
What do you guys think/run for highway cruising?
Old Sep 29, 2011 | 11:30 AM
nitrous2fast's Avatar
It really depends on cam, combustion chamber efficiency, compression ratio, and a little bit with A/F ratio. Not knowing how your heads were ported makes it hard to guess. Also what A/F are you running at cruise?
If the mixture is leaner than 14.7 it might not require as much timing. If richer it would typically take more.
Old Sep 29, 2011 | 12:44 PM
kgkern01's Avatar
Ported stock heads 52mm chamber, 11.7 SCR 9.3 DCR, 226/226 110 LCA cam. 14.3-15.3 AF cruising.
Old Sep 29, 2011 | 08:19 PM
Are you sure you are at 14.3-15.3??? if you are running E85 it shouldn't be there.
Anyways a good indication of where you should be is to advance the timing and see if you create more vacuum. If you do; keep going until you stop making more vacuum. Then pull about 2-3 degrees out to give a little room. THIS is only for the cells that you are in while cruising!!!!
Old Sep 30, 2011 | 07:46 AM
kgkern01's Avatar
My wideband gauge is still set to gas, so when reading 14.7 = stoich. I'll try tuning by the vacuum.
