Heads "MILLED" .030
I think it was mentioned but the LT1's have an adjustable valvetrain and the 302's don't hence needing a shim.
Yes the LT1's use the regular SBC springs. After you decide what cam you are going with then decide on your springs.
Just depending on what you want to do with the car there are better cams than the hot cam and especially the edelcrock.
Here are a good set of spings I am using. The hot cam springs are cheap, but will barely work with a hot cam. These are good to 600 lift I believe and are very reasonable IMHO. So check them out
http://www.summitracing.com/parts/HRS-98215/
hth
andy schuck
hth
andy schuck
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
