Supercharged Stroker Q's
Old Oct 5, 2011 | 08:34 PM
Ponyhntr's Avatar
Originally Posted by firefighter34
Ponyhuntr; much ablidged! (in reference to your first post) In reference to your second post; was that a block somebody bought and didnt finish or you found somewhere selling a short block for a steal?
Kinda both. The guy had the shortblock built and assembled, then he needed cash, so he sold everything. It was brand new and ready to go, just needed a set of heads and an intake bolted on and it ran. Unfortunately this kind of stuff happens all the time, so the deals are out there.
Old Oct 5, 2011 | 08:37 PM
firefighter34's Avatar
Sweet, thanks for the info!
Old Oct 5, 2011 | 08:43 PM
Ponyhntr's Avatar
Also, don't think you need to spend $6k on a shortblock (or engine for that matter) for it to be able to handle boost. People make 1000+ hp all the time on Eagle crank and rods, and good pistons like JE or Diamond.
Old Oct 5, 2011 | 09:36 PM
Thats good news! I went from planning on building a stroker this winter to re thinking the whole thing.......I think I will just aquire the parts as I can and then put it together next year....
Old Oct 5, 2011 | 09:46 PM
[QUOTE=IronOutlaw;15461207]This is what Im modeling my build after.
http://www.ellweinengines.com/Ellwei...Kit/355Kit.htm
So this looks like a pretty good build but it seems like you can buy a 383 short block for close to the same price and thats not finding a steal.... Am I missing something?
Old Oct 5, 2011 | 09:56 PM
Ponyhntr's Avatar
[QUOTE=firefighter34;15474424]
I have no idea where they got that number from. I would not run a stock crank with boost, and my personal opinion I wouldn't run Mahle pistons either.
Old Oct 5, 2011 | 10:19 PM
[QUOTE=Ponyhntr;15474465][QUOTE=firefighter34;15474424]
I have no idea where they got that number from. I would not run a stock crank with boost, and my personal opinion I wouldn't run Mahle pistons either.[/QUOTS
Sounds good! Thanks for all the info!
Old Oct 5, 2011 | 11:20 PM
IronOutlaw's Avatar
If you read in my original post that build is for an NA stock stroke motor. I was suggesting that earlier in the thread because of your low budget. If you are serious about going forced induction then your gonna need stronger heavier duty parts. A lot of people do buy used or half built setups successfully, but I am too scared of getting ripped off. I figure I may end up spending more money, but I know exactly what parts are going into the motor from the bottom up.
Old Oct 6, 2011 | 12:58 PM
[QUOTE=IronOutlaw;15474809]
Ya that makes sense as well... I think i have closed the door in the blower atleast for the forseable future.... I will just stick with a solid stroker build.....
What are the advantages of buying a short block versus rebuidling and boring a stock bottem end of the current motor?
