lt1-427
Old Oct 5, 2011 | 09:04 PM
whytryz28's Avatar
Cant you send the block to Donovan and have them sleeve it?
Old Oct 5, 2011 | 10:39 PM
Puck's Avatar
A lot of places can sleeve a block, and its been done before. There are just better ways to spend your money.
If you are planning on building a 400+ CI LT, then you better have some deep pockets to afford a valvetrain and badass heads to let it breathe.
Old Oct 5, 2011 | 11:01 PM
Valkyn's Avatar
Whatever happened to those LTX GM performance blocks that got auctioned off on ebay? I remember seeing a thread about atleast one being sold for like 10 grand.
Anyone know whatever came of it?
Old Oct 6, 2011 | 02:49 PM
ahritchie's Avatar
Apparently, they still come up for sale once in a blue moon: https://ls1tech.com/forums/lt1-lt4-m...ce-shop-2.html
Somebody needs to make a 454 LT1!
Old Oct 6, 2011 | 04:37 PM
BIGCAT7274's Avatar
Originally Posted by tealchevy08
Is it possible to turn my LT1 into a. 427 or will the cylinder walls be to thin to make a lot of power
it can be done but the ring pkg would not be pretty. 4.06 bore and a 4.10 stroke would give you 425". realistically i would not go any less than a 1" compression height.
Old Oct 6, 2011 | 06:27 PM
Rob94hawk's Avatar
Originally Posted by BizZzatch350
Your thinking of Mark Montalvo, he built a 421" LT1 that made over 800rwhp on nitrous. He used to post as VPREATR.
Yup. Remember him.
What is the deckheight on the bowtie? It must be taller than stock. Well I would hope it would be anyway.
I was nagging Dart for a while to build it since they teased us with their idea of producing their own LT1 bigblock.
Old Oct 6, 2011 | 06:29 PM
Z28Roxy's Avatar
Originally Posted by transbird95
You will need special hyperconducive pistons and to weld the ring and pinion for that.
He will need Johnson rods for that kind of power.
Old Oct 6, 2011 | 06:51 PM
joelster's Avatar
I have a 414" LT1. 4.060" bore with a 4" stroke. This is the piston used:
http://www.summitracing.com/parts/MLE-SBC000060F05/
The bottom of the block is not clearanced any more than a typical 383. The way the shop accomplished this is with a particular I-beam rod. A Scat pro-comp. It offers way more room than a big H-beam. I honestly don't know if a 4.1" stroke crank would fit. I'm 100% positive that it would not hit the block. My block has more than .1" of room as the crank swings, BUT I think there would be issues with the rods smacking the camshaft. I run a .900" base circle, and it's pretty close. If the clearance between the rods and camshaft are tight bad things will happen if you start to get a little flex in the cam. I don't know of anyone that has put a 4.1" stroke crank into an LT1 or an SBC with standard cam location. If someone has heard of one please post the link.
Old Oct 6, 2011 | 07:02 PM
BizZzatch350's Avatar
Moderator
Originally Posted by Rob94hawk
Yup. Remember him.
He was around CZ28.com back when JimLab and Mind Game used to post on there. Not quite sure what ever happened to any of those guys.
Old Oct 7, 2011 | 11:52 AM
JasonShort's Avatar
Moderator
Mark ripped a few people off of quite a bit of money. JimLab and myself included. He stopped posting after we had his local police department involved. Shocker
Old Oct 8, 2011 | 06:46 AM
pillarpod's Avatar
Is tat an estimate
I wanna built n engine tat pushes out over 1000hp n have it as a daily driver wit a 12bolt or bigger rear end
Old Oct 8, 2011 | 08:50 AM
  #32
ElkySS's Avatar
no one ever realizes just how much power 1000hp is. hell my car should be around 500rwhp and it can be hard to control on street tires. im pretty sure u couldnt get close to wot in any gear without blowing the tires off.
Old Oct 8, 2011 | 09:00 AM
  #33
transbird95's Avatar
I think he should just buy a pro mod.
Old Oct 8, 2011 | 09:26 AM
  #34
ZFreie's Avatar
Tubbed slicks duh lol
Old Oct 8, 2011 | 11:15 AM
  #35
ElkySS's Avatar
he said daily driving
Old Oct 8, 2011 | 06:28 PM
  #36
GREGG 97Z's Avatar
He'll I was only around 375 at the wheels and in 1st & 2nd it would get loose on the street. Can't even fathom 1000, lol...
Old Oct 8, 2011 | 07:46 PM
  #37
alexcoreas's Avatar
Old Oct 8, 2011 | 08:32 PM
  #38
merim123's Avatar
there is a nice Ellwein build he did as a 399. Used some parts I haven't seen used before, especially the crank (callies magnum XL with 1.88 journals and a BBC nose?) Look at the clearance he attributes to the 1.88 journals.
sorry for the big pics, they are linked to Ellwein site.
Old Feb 14, 2013 | 02:46 PM
  #39
bufmatmuslepants's Avatar
BUMP BUMP what happened with this motor?
Old Feb 14, 2013 | 02:58 PM
  #40
quik95lt1's Avatar
so legit question........why HAS nobody sleeved an LT block?
