My junk.
Old Oct 6, 2011 | 11:53 PM
AChotrod's Avatar
Default My junk.
Old Oct 6, 2011 | 11:55 PM
Rob94hawk's Avatar
Nice junk in your living room on the hardwood floors.
Details? Or do we have to guess?
Old Oct 7, 2011 | 12:04 AM
AChotrod's Avatar
lol yeah my house is the garage. 383 LT1 SRP -5 cc pistons, eagle forged crank, eagle h-beam rods, howards billet splayed capps, hell fire rings & arp every where and a half fill. Should be good to go
Old Oct 7, 2011 | 06:41 AM
pillarpod's Avatar
its all junk, i'd throw it too
Old Oct 7, 2011 | 09:57 AM
91rs355's Avatar
Looks good bud, nice build. What type of heads are you going to run.
Old Oct 7, 2011 | 10:02 AM
ZFreie's Avatar
Looks awful, its all clean and shiny...
although, your missing some parts. Seems like the oil pan is the only main one lol
Looks good man, what else you have in store for it?
Old Oct 7, 2011 | 10:28 AM
merim123's Avatar
looks good, I have those same pistons in my junk. What heads are you planning on here?
Old Oct 7, 2011 | 10:39 AM
sweetbmxrider's Avatar
Surprised a baller like you went with eagle
Old Oct 7, 2011 | 10:54 AM
93BlackZ28's Avatar
<------ Jelly
Old Oct 7, 2011 | 11:44 AM
Larry @ AMS's Avatar
nice! I'm happy to see you finally have it.
Old Oct 7, 2011 | 11:52 AM
defaultexistence's Avatar
Looks exactly like junk minus the half fill and 4bolt caps... Nice
Old Oct 7, 2011 | 12:10 PM
draggin97s10's Avatar
Your wood floors are nicer then mine, but mine were put in, in 1927
Old Oct 7, 2011 | 12:19 PM
AChotrod's Avatar
I think Eagle is way under rated and have no issues with their forged stuff. Hell after all records have been set using them. Like Bob Kurgans NMCA drag radial pass at 7.85@175
Thanks Larry! If it wasnt for you this car wouldnt be anywhere near it is. Thanks for hooking me up with Eric.
As for the heads Its going to use my current LE2s(for now) a LE ported Vic jr with Nitrous Outlet spray bar, a LE HR custom cam,and a built TH350. Should be good for mid 9s maybe faster in good weather. Ill build it over the winter since its so late in the season already.
Old Oct 7, 2011 | 12:22 PM
AChotrod's Avatar
LOL Im the manager of the largest flooring store in Chicago and had them redone a few years ago. They are from the 50s though.
Old Oct 7, 2011 | 12:24 PM
Curious, how did the cranks journals look did they have to be cleaned up and polished again before balancing? Or were they good Outta the box?
Old Oct 7, 2011 | 12:39 PM
AChotrod's Avatar
I actually bought a brand new 383 with -16cc pistons from a guy that needed cash for 350 bucks. The engine was never run and came with a PP balancer, lifters, timing set, new vented opti, cam, timing cover etc. Deal of a lifetime. Only prob with the motor was somehow when the kid was away at school the oil pan got filled with water and froze so he sold it dirt cheap. I wanted more compression anyways and splayed caps so Larry hooked me up with my builder. Anyways everything looked and checked out great except the bores were on the tight side for spray and the caps were already align honed so we started with a new block. The crank just got a quick polish and was good to go, and the rods got a hone on the big end to make everything perfect. I would say after I sold some of the stuff that came in the orig 383 I have about 2k in this one the way it sits. My builder says there is absolutely nothing wrong with Eagle forged stuff and has seen more failures with higher end parts.
Old Oct 7, 2011 | 01:01 PM
355z28's Avatar
Looks close to mine with the billet caps, half fill. I just used compstar and carrillo for a rotating assembly. Pretty excited to see this thing going. You still going to rock a HYD roller cam?
Old Oct 7, 2011 | 02:24 PM
AChotrod's Avatar
yes it will have a LE custom HR cam like mentioned above. Already have it sitting in my bedroom.
Old Oct 7, 2011 | 03:06 PM
I ran Eagle rotating in my 96 so I would have no concerns on the setup you have. I have always enjoyed helping you out anyway I could. I'm sure the car will meet your 9 sec goal once you get the package together and actually get away from work to test the car.
Old Oct 7, 2011 | 03:49 PM
Puck's Avatar
Identical to my shortblock half fill and all except for the caps, mine are Eagle lol. Also, I have L19 rod bolts instead of the 2000s so it took a bit more clearancing.
Can't wait to see it finished, how much do you plan on spraying?
