Header question's
Old Oct 11, 2011 | 10:21 PM
fastredlt1's Avatar
Default Header question's
So I'm putting pace setter LT headers on my 97 TA. The two question's I have are, can I put the driver side in from the top and do I need to remove the steering rod??
Old Oct 11, 2011 | 10:39 PM
IronOutlaw's Avatar
I had to unbolt the steering shaft to install my pacesetters. I went in through the bottom with the drivers side though. Where all of the primarys come together at the collector was too wide to slide in from the top.
Old Oct 11, 2011 | 10:47 PM
fastredlt1's Avatar
Default Headers
Did you unbolt the rack from where the two shafts meet?
Old Oct 11, 2011 | 10:52 PM
IronOutlaw's Avatar
Yeah, I unbolted it where the two shafts meet. This left the top shaft where it normally sits and allowd the bottom shaft to be moved out of the way.
Old Oct 11, 2011 | 10:54 PM
fastredlt1's Avatar
Default Headers
Sounds good. Thanks for your time and help.
Old Oct 12, 2011 | 02:43 AM
Quazz's Avatar
I have the Pacesetter LTs and I love them. The only issue I have is changing the #6 plug, as I don't have that shorty SP socket from SLP. I had to loosen the header to get it out last time.
