396 SR Setups
Old Oct 14, 2011 | 06:44 AM
Formula934's Avatar
Default 396 SR Setups
Hey guys,
I am thinking about maybe going to a Solid Roller setup in the spring. I'd like to see some ideas on a cam or maybe see some similair setups you guys have.
For the purposes of getting specific feedback i will set some ground rules.
1. As of right now, the car is a weekend warrior at best, so with a SR swap i will still only be driving the car on weekends.
2. The car utilizes 93 octane and will still operate on pump gas after SR swap
3. Peak power on current setup is 6300 rpm, I want to keep the factory PCM so i will not be revving past 7000 rpm
4. The car has incredible street mannors right now but im willing to give up SOME drivability in the new set up.
5. Id like to increase the valve lift with the new setup to maximize the potential of the AFR 210 heads, however, PTV clearance must also be kept in mind.
6. RWHP goal is 480-490 give or take
Here is my current setup, I will also be switching to an EWP (FYI):
396ci
AFR210 race ready 55cc
58 mm holly TB
3" dual X-pipe w/ flowmaster 10 series mufflers
LT4 intake
Hydrolic roller
Cam Specs:
rocker arm ratio is 1.6 intake 1.52 exhaust.
cam...248/254 Duration @.050 lobe lift .375/.387
valve lift .600/.588 108LSA
Comp Ratio:
13.1 static
465RWHP
426RWTQ
93 octane
Old Oct 14, 2011 | 07:24 AM
quik95lt1's Avatar
thats some good cam in there already but you could step it up for a 396............thing you are going to have to be careful with is the 7000rpm limit that puts a hamper on the power you can make and the cam you can run...........what i can tell you is the little extra $$ to do the solid setup right goes a long way in durability.........IMO a shaft rocker setup is a MUST with anything more than a very mild solid roller.......give advanced induction a call they are very good with what you are looking to do........they did the solid roller in my car and it runs great and has great manners also...
Old Oct 14, 2011 | 07:28 AM
Formula934's Avatar
ya i'll give them a call. I think the big issue will be the PTV clearance with 55 cc heads. Im cutting it pretty close as it is lol.
Old Oct 14, 2011 | 07:41 AM
quik95lt1's Avatar
all has to do with the lobe thats designed...........you'll be supprised how close you can cut it if you run good parts and proper geometry..........im running .039 intake and .047 exhaust revving in excess of 8000rpm with no issues at all.....this is the tightest its ever been i have my lash down to .008 car runs the best tight
Old Oct 14, 2011 | 07:59 AM
Formula934's Avatar
Ya thats a very tight setup you have, 8000rpms damn, what are you running for a rear end gear?
Old Oct 14, 2011 | 08:01 AM
vetteboy99's Avatar
Screw n/a! TT or twin screw supercharger FTW!!
Old Oct 14, 2011 | 08:05 AM
quik95lt1's Avatar
4.56's....makes peak at 7450 and solild power out to about 8200......the car was crossing at 7900 before but with the added mph its running now its crossing around 8100-8200
naaaaa........i dont need them things........rather use my brain than just bolt an oversized leaf blower on my car..........
Old Oct 14, 2011 | 08:15 AM
Formula934's Avatar
4.56s that what i thought, that thing must be a god damn space shuttle off the line lol, ive pondered the thought of 4.56s but i cant hook up as it is, must be fun as hell to drive though
Old Oct 14, 2011 | 08:58 AM
quik95lt1's Avatar
it leaves well.......runs 1.33-1.35 60's pretty consistantly.......and they are perfect on the highway too 70mph is like 2800rpm locked up in overdrive........heres a vid of the car leaving.........
http://www.youtube.com/watch?v=ilQ_a__lFrU
Old Oct 14, 2011 | 09:40 AM
SS RRR's Avatar
Village Troll
The problem I see is reaching that power goal and staying under 7000rpm with a SR. I can't recommend any sort of cam because the HR you are running is larger than the SR I am currently running.
Old Oct 14, 2011 | 09:44 AM
quik95lt1's Avatar
yea its gonna limit him for sure but he can do better than whats in there and still stay under 7000.........long as he keeps it on a low ICL/LSA it will help alot....id run a 106ish lsa in that car
Old Oct 14, 2011 | 11:17 AM
bowtienut's Avatar
I was thinking the same thing. I bet a solid roller with the same effective duration (when you take the lash out) as his present HR could keep his hp peak near the same rpm, but the more aggressive ramps permitted by the SR lobes can fatten up the entire power curve.
I'm running a 228 duration/108 lsa HR in my 350, and bumping the PCM limit on shifts. Power peak at 6400 rpm. I've toyed with the idea of a solid roller which wouldn't want to rev any higher but would boost the existing curve, especially down around 5500 where it falls after the shifts. It just doesn't seem right for me to think about that on a stock shortblock though
Formula934's Avatar
How much do you think im being limited by the stock pcm? Hypothetically speaking though, what is involved in the pcm swap? Im assuming most of you guys running past 7000 rpm are running ls1 pcms? I'm a seasoned tuner cat guy so im wondering what the differences would be in the tables and physical set up of the pcm. I'd really like to stay away from changing wiring harnesses etc.
Old Oct 14, 2011 | 11:22 AM
Puck's Avatar
With stock valve spacing heads like the 210s and a decent valve relief piston you can run a hell of a cam without ptv issues. I ran into problems but my cam is a very aggressive lobe with early evo and my heads are 60/40. If they were stock spacing I would be fine, but the valves don't sit properly into my srp pistons.
Old Oct 14, 2011 | 11:30 AM
97 6speed z's Avatar
Hey guys,
396ci
58 mm holly TB
LT4 intake
Hydrolic roller
Cam Specs:
Comp Ratio:
13.1 static
465RWHP
426RWTQ
93 octane
You say you're thinking of going SR just to increase valve lift to take advantage of those AFR 210 heads, but, with the 248/254 duration HR you are currently running you have PLENTY of duration to get to say .625"/.635" valve lift simply by running a slightly higher lift HR grind.
With your current .387 exhaust lobe lift and a change to 1.6:1 exhaust rockers, you would be at .619" exhaust valve lift with this cam. If you are NOT on a small base circle cam grind due to being a 396 stroker motor .... you could easily have a new HR cam ground with say 250/256 duration and .390/.395 lobe lift yielding .624"/.632" valve lift with 1.6:1 rockers. Running 1.7:1 rockers on this "higher lift" HR cam would give you .663"/.671" valve lift. How much valve lift are you looking for???
Old Oct 14, 2011 | 11:46 AM
Formula934's Avatar
Been there, done that, with 1.6 on the exhaust with this cam and ask me why its now 1.5. I know i could get another grind with slightly larger lift number on the exhaust, but im playing on the danger side with a HR setup.
Old Oct 14, 2011 | 11:49 AM
Formula934's Avatar
Yes, small base circle cam. Was at .619 on the exhaust with PTV issues.
Old Oct 14, 2011 | 11:50 AM
bowtienut's Avatar
Originally Posted by 97 6speed z
....With your current .387 exhaust lobe lift and a change to 1.6:1 exhaust rockers, you would be at .619" exhaust valve lift with this cam. ....
The OP may already know that extra exhaust lift is not always your friend once you get to higher lifts, like a few of us have found out. I also run 1.6/1.52 rockers on my .383/.383 lobes, which helped the power curve without harming the peak.
I agree with you that there is some potential left in another HR grind; heck, IMO, unless those heads are not as good as I think they are, he hasn't optimized the power with the cam he has in it right now.
But.......you can't deny that he's already running a pretty stout setup, so he sounds as "greedy" as the rest of us , so I can understand and support the notion of a SR if he's going to make any change at all.
Old Oct 14, 2011 | 12:23 PM
quik95lt1's Avatar
what does the base circle have to do with the cam he has now. vs. what he choses? any aftermarket cam will have a slightly smaller base circle......imo i would switch over to the SR and stop dicking around with HR stuff.......ground correctly you can make more power and stay under your 7000rpm limit........and in reality be more durable and have more rpm head room than an agressive HR cam......
yepppp.........i took just a hair off my pistons for radial clearance of the valve....
How much do you think im being limited by the stock pcm? Hypothetically speaking though, what is involved in the pcm swap? Im assuming most of you guys running past 7000 rpm are running ls1 pcms? I'm a seasoned tuner cat guy so im wondering what the differences would be in the tables and physical set up of the pcm. I really like to stay away from changing wiring harnesses etc.
FAST XFI here worth every penny........great system id buy it again in a heartbeat
ahhhh greed makes us fast lol ..............id run the solid in it....dont be afraid of it they work great and if done correctly last a longggg time.......ive been running over .700 valve lift with a PSI double endurance spring and after 3 years and hundreds of passes and street driving they have not detioriated a bit by way of pressure......
Old Oct 14, 2011 | 12:32 PM
Don't know what I'm missing but, I sorta agree with Puck here. Even with a 3.875" stroke LT1 motor ..... PTV problems at .619" valve lift seems very odd???
Let's try this another way, OP what would be your "ideal" exhaust and intake valve lifts for those AFR 210 heads???
Bowtienut, nothing worse than spending more good money on something only a little different. I responded to the limiting conditions the OP imposed in his first post, by just pointing out that he didn't need to make the "jump" to a SR valve train just to get the higher valve lift numbers he appeared to be after. We ALL know the benefits that can be had with SR setups over HR, but with only a 1) 7,000 RPM ceiling imposed, 2) 93 octane fuel requirement, and 3) only "slightly reduced" street driveabilty ............ he surely didn't sound like he was looking for "Top Fuel" performance here.
OP, if you want a SR setup, by all means get yourself one. I was just offering you an alternative to get what you originally stated you wanted ....... without having to go SR (with it's required increased maintence, (read semi-regular valve lashing), noise, and street driveability concerns).
