AEM wideband
I this the wideband that people are have good luck with ?
I have the innovative guage and its a pos and wont work and just keeps flashing. It is a very common issue with that guage after i googled it. Also i heard that the AEM is much easier to install. Is that true?
zip-tied the wiring away from the exhaust
ran it up the tranny tunnel, through the hole for the shifter (you having an automatic prolly means you will need to make a hole), behind the radio and into one of the ac vents i popped out.
since i do not use the stereo much we tied power to the feed for the head unit. (i am sure there is a better way but i didnt really care)
You can definitely find it cheaper than $200 also.
Best price I saw, $165 shipped.
I've hooked up the serial to EFI Live, it was easy also.
It's super easy to install. My car already had a wideband bung welded into the exhaust so all I did was screw it in nice and tight and plug it in to the gauge and you're good. Route the wires however you want to and you're done. It seems to be very accurate, some guys say it's not the best but for the money you definitely won't find a better one and it has been good to me so far.
