How to remove the Clutch Master Cylinder
Old Mar 9, 2004 | 07:41 PM
Gangly's Avatar
Default How to remove the Clutch Master Cylinder
Whats the easiets/best way to get to and remove the Clutch Master Cylinder
Old Mar 14, 2004 | 06:00 PM
93TAWicked1's Avatar
Unbolt the brake booster and pull it up and little out of the way then undo the bolts inside and pull the U-bolt in the back. The resovoir, line, MC and slave are all one piece so if you want to replace the MC just buy a new setup from GM they are like 85 bucks for it all sealed and bled from a discount dealer. When installing it is ALOT easier to use bolts instead of the Ubolt.
If you are doing a Adjustable MC good luck bleeding it its a bitch!!
Bobby
