All the catted y pipes/fit pacesetter LTs
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Picked up some pacesetter race headers, need catted Y pipe. Can u list all the catted Ys that fit my headers? Looking for best priced thanks
IMHO you best bet is to buy the Pacesetter Y and have some cats welded on to it..Here is a link pay attention to the pics this is an emissions compliant LT1 something simular you want to do..look at the Y pipe..also if your looking for good cats try thunderbolt..
https://ls1tech.com/forums/lt1-lt4-m...ideo-pics.html
http://performance-curve.com/3thunde...ter415300.aspx
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
wow thanks most helpful, what about tampering of cat location since i have one cat stock at the merge? they say anything about that?
95mysticta where did you place your cut out with having a catted Y pipe? i have a cutout i need to install with the rest of this stuff
Its all dependant upon if you have to pass the sniffer test. If you have visual inspection then you could run it at the end of the y at the merge. If you need to pass the sniffer then you have to run them the way I have in the pics. If the cats don't get hot enough they won't function. The closer they are to the collectors the better they will perform. You can take your chances with the bullet style cats but they don't perform as well as a fullsize cat. So if you have a decent size cam in there your going to want to make as easy as possible to get it to pass. I run my cutout in the right tailpipe slot in my borla catback.
Mine isnt crazy loud because its not a dump under the car it still exits out the rear tail pipe just doesnt go through the muffler. I personally love the way it sounds and at the flick of a switch i can have it stealthy or a nice grunt all without having a dump under the car giving off drone and the other issues that go with having one there.
GMMG with no cats is very loud. You will get rasp from the 2-3k range. Sounds amazing at WOT, but IMO it sounds better overall with a catted y. I threw my off road y on over the summer this year and I much prefer the catted y I had on it. It will still be plenty loud with cats and all of the rasp will be gone. I used two Thunderbolt mini cats in my y pipe. Never had a problem with visual inspection.
