wheel adapters
Old Oct 19, 2011 | 08:37 PM
white ghost's Avatar
Default wheel adapters
Hi all, need some infinite knowledge. I know the wheel section could also answer, but id rather talk to y'all. Would a wheel adapter listed as 1.25" actually add 2.5" on the outside length or just a portion of that. Wanting to change bolt pattern with an adapter. Thanks in advance.
Old Oct 19, 2011 | 08:40 PM
the_merv's Avatar
Veteran: Air Force
That 1.25" Adapter is going to add 1.25" to that Axle..so yes in total the rear width would be 2.5" wider, 1.25" on each side.
Old Oct 19, 2011 | 09:13 PM
Thanks mercy, so being the adapted is 1.25" so it will add 1" on both ends?
Old Oct 19, 2011 | 09:31 PM
the_merv's Avatar
Veteran: Air Force
My keyobard fcked up..lol.. 1.25" is adding 1.25" to the axle face..1" is adding 1"..
