Copper Braided ground wire??
Old Oct 19, 2011 | 10:23 PM
Badazz 97 TA's Avatar
Default Copper Braided ground wire??
What does that brittle copper wire actually ground? Im replacing it, but just wondering what it does. It goes from the coil stud to the frame.
Old Oct 19, 2011 | 11:06 PM
shbox's Avatar
It is a way to additionally ground the engine to the frame in an effort to keep the ground potentials the same.
Old Oct 19, 2011 | 11:29 PM
SoxXpupPeT's Avatar
thats all it does. get some grounding straps from summit and add them from your shock tower to where your alternator is and where your coil is. thats what i did but i like overkill
Old Oct 20, 2011 | 11:11 PM
fex77k's Avatar
I just bought a BBC ground strap from summit for less than $10 and put it right where the coil is.
Old Oct 20, 2011 | 11:19 PM
ok good info. Good to know.
Old Oct 21, 2011 | 05:49 AM
RamAir95TA's Avatar
It is ALWAYS good to have a bigger ground strap. Helps to eliminate many electrical gremlins. I have a 1" wide strap that goes from the cylinder head to the OEM location with star washers to bite into the metal on the frame rail.
Old Oct 21, 2011 | 08:49 AM
merim123's Avatar
any one have a good link/part # on one of the thicker straps. I wouldn't mind upgrading. Searched on summit, saw a few, but can't tell the thickness.
Old Oct 21, 2011 | 09:04 AM
RamAir95TA's Avatar
They are all the same really...just pick one.
Old Oct 21, 2011 | 09:25 AM
merim123's Avatar
thank you sir.
Old Oct 21, 2011 | 10:38 AM
fex77k's Avatar
Search 148014 on summit, its really wide and it will fit on the stud coming off the side of the coil mount.
