Carbed LT1 using the ECM to run the optispark
Old Jan 3, 2024 | 09:46 PM
Groover's Avatar
Default Gauge
If it’ll run using optispark and ecm than most things will probably still function ie tach, speedometer, cooling fans and fueling?
cheers
Old Jan 13, 2024 | 09:28 AM
KW Baraka's Avatar
cheers
Really dude? Responding to a 12 year old thread?
Old Jan 16, 2024 | 06:19 PM
Groover's Avatar
Originally Posted by rkinney
I planned to use the 93 ECM and harness. I was going to eliminate the injector, o2's, iac, egr, and sec air wiring. Map, tps, ect, opti-coil-module, knock sensor, and vss (for datalogging not function) would be hooked up. I think it will work, hoping the ECM doesn't go into limp mode. I am going to try it and will get back with my results. I'm just about to start the swap.
Hello so how did the carb set up work out for running off the opti spark?
Cheers
