I need help
Old Oct 24, 2011 | 11:51 AM
unleashedperformance's Avatar
Default I need help
I havent posted here in awhile due to deployments in the marine corps. I had the engine built for my s10. The motor is a lt1 with ported heads and a custom grind LE cam. My problem is i have no spark. I have replaced the coil, icm, distributor optispark, ect. I still dont havr any spark. Everything in the ignition has power and its 5volt references. I havehave check all the wires for continuity and ohmed all themy ignition wires. I have fuel pressure. Will the computer keep the ignition from having a spark. And if so what would be a good place to start?
Old Oct 24, 2011 | 11:55 AM
lt1slowz28's Avatar
where does the no spark start? like does the coil put out a spark or does it stop further down the line?
check the plug on the passenger side going into the top of the opti, if it isn't seated all the way it won't work, ask me how I know.
mcalus's Avatar
Crankshaft position sensor? My Lincoln with a 4.6 would crank but I didn't have spark. Checked it and the plug was dirty. Worth a shot
Just curious, what's the specs on the cam?
Old Oct 24, 2011 | 11:58 AM
gatorhead's Avatar
My favorite anser to give wors for this as well, CHECK ALL GROUNDS!
Old Oct 24, 2011 | 03:28 PM
The coil does not spark. The cam specs is 270/276 510 lift 111. Lobe sep. +4 for nitrous. I look for a crank position sensor. My motor doesnt have one. I have a 95/96 msd opti. Ive bren tryin to trace wires. But of course it has a s10 harness and a camaro harness and i cant find a diagram to go off of. Does the driver in the computer go bad or does it have internal grounds guess ill just send the computer to pcm for less
Old Oct 24, 2011 | 08:25 PM
gatorhead's Avatar
www.shbox.com
That gives you the fbody wiring diagrams. You would have to match that with your s10 wioring, and I am only assuming you used the pcm from the fbody??
The PCM does have drivers in it that provide ground to some and it toggles voltage for others. It has to toggle from 0-5v to the icm for the coil to spark, so signal from the opti to the pcm to the icm to the coil back to the opti. it goes from signal to spark.
