Gooddbye LT1
if you're cash strapped, the best option is to get a used motor until that situation improves. Getting a low mileage LS1 will be expensive and it's so old that you will not be able to get a reasonable interest rate on a loan.
If your low on cash get a hold of some of that ring sealer gunk....and keep throwing that in it and limp by. Just dont expect performance from it....
I would definitely go back and talk to the rebuild shop.
Go to craigslist and try to score another LT1......these engine have been well documented to beat Ls1 engines all the time also.
On San Pedro and 28th street to be exact I see a lot of camaros come out of there with rebuilds. Or check out castillos and son. Majority of the camaro BOYS car club builds their engine with them
Kinda sucks I put all that time and money into exhaust, sfc's, paint, etc, but it seems more economical to me to put a down payment on an ls1 car and make payments rather than make another big purchase on any type of motor swap, rebuild, etc, which can have mounting costs and I'd have to pay all at once, unlike a car loan. Of course I'll have to wait awhile before that can even happen. And again, who knows what else will go wrong and I'm in the same spot again with no protection or warranty or anything. I'm still thinking of a way to make it work but I don't think I can stomach it. I'm just tired.
You can score the trannys for these a dime a dozen.
Your compression problem could be incorrectly set rings....you wont really really know for sure until it all comes apart.
Is the shop responsible? for sure.
Will an LS1 car cure your ailments..? hate to break it to you but not necessarily....they have their own ailments as well.(check on piston slap and oil burning) So with a little luck you wont have problems...but with the gremlins chasing you..you could have more.
If your tired. Which these cars can be....I would cover the car up for a year+.
Buy yourself a Honda...and im not ragging on you here. By yourself a 90' and up honda with relatively low miles. And just beat on it...ride it...peacefully get to where u need to go. Then later uncover the beast with new ideas and patience.
She looks worth keeping to me. Now if you have frame damage...then sell it off for sure.
If they punched out the block...and the bores are still good. It's salvageable.
But like some of these guys have written...a good shop is hard to find.
Some of the better ones don't even like to check clearances if it's "just a street engine". So even the good ones can be scumby's as well unless your giving up large doe for their "race engines".
time consuming, but easy (conservative times):
1) drain fluids (20-30 Min)
2) disconnect harness inside car and pull it in the engine bay (20-30 Min)
3) disconnect hoses and steering column. (20-30 min)
4) disconnect brakes lines at ABS (if you have it) (10-15 min)
5) disconnect driveshaft and exhaust at cat (20-30 min)
6) support kmember/trans (mover's dollies work great)
7) disconnect sway bar from frame (20 min)
8) take out the 6 k-member bolts (20-30 min)
9) raise car and roll out engine/trans combo
so in about 4-5 hours you can ge the engine/trans out. Spend about 2-4 hours swapping parts over to the used engine and then get it back in, connect everything and fill up all fluids and start her up!
Ok it may take longer, but I feel like you've created a mountain out of a hill and it's just a hill.
your car is clean and looks good why not spend a weekend and get it running again, especially if you are cash strapped.
right there.
