Looking for some opinions
Im not sure how expensive itll be to build a lm7, but an lt1 stroker wont be cheap.
Remember theres 2 main parts to the engine 1)top end and 2)bottom.
Once you get your pistons, rods, crank, bearings, etc.. youll only be half done with engine parts only. NExt will be the top end and other random stuff which include:
1. cam
2. rockers & studs
3. pushrods
4. guideplates
5. lifters
6. valve springs
7. timing chain & sprockets
8. oil pump
9. Plugs & wires
10. fluids
11. heads
12. gaskets
After youre done with engine parts, youll need to focus on transmission, rear end, suspension, and other random bolt ons if you want to do things right. None of this includes shop labor either.
If you do stay lt1 you need to either do a .030 over 355 with the stock crank, or a 383 with a forged crank rods and pistons. Do a search on eagle cast cranks and you will see why not to use them.
