Tune vs tire size
Second, gear ratio in the rear-end has nothing to do with the "tune" or "air-to-fuel" ratio. It is simply the ration at which the axles spin in relation to the driveshaft. I have r2ear ends, one with 4:10's and the stock 3:42's. The only thing affected between the two is the ratio the speedometer is programmed for. If I change rear-ends, I have to reprogram the speedo. The tires I chose for my 19" wheels are very close in height to my stock 17" wheels (less than .3")...however my speedometer would be slightly off when I switch.
Third, there are a lot of variables that can be causing the minimal gains. First, human error...can you make the same pass everytime. Track temp, Air temp, tire temp, tire air pressure, humidity...
I also have pcmforless tune. Much better than a programmer, not quite as good as a dyno tune.
