F#ck Optis...
Go buy a 50 cent light bulb at Pep Boys. Go home. Submit the online survey. Print out the 10% coupon. Go back to Pep Boys and buy new boxed coils-with a warranty. Use your 10% coupon.
Moving to the LTCC system is the next step up in reliability-and it definitely helps engine response. It's the only thing that made my '94 a daily driver.
Of course, if I had a LT1 car and had to do it all over today, the EFI24x system would be number one on my to do list.
If you go with the LTCC system, specify LS2 coil plugs and use LS2 coils, they out perform the LS1 coils. You cannot use the round heat-sinked truck coils with the LTCC system.
And yes, the MSD LS coils are crap.
The heat sinked truck coils are a very different animal than any of the other coils.
Changed a cap and rotor once on a 140,000 mile 15 year old opti, that's it.
-Dustin-
Im saying this while my car is down cause the opti went out
Dynaspark installed and chasing wiring issues in my own car. Ive had my LT1 car about 5-6 years, 2 motors, 3 transmissions, 2 rearends, and my 3rd opti...fun fun. My biggest complaint with the opti is how damn hard it is to do anything to them. Even plug wires are a major PITA. After owning an ls1 car for 2 years I am spoiled.
Changed mine once, wasnt that big of a deal.
At this point, I dont think I could do a 24x conversion.
A 5.3 LS swap would be just a much better route IMO. I bet it would almost be similar in cost assuming I sold all of my LT1 stuff.
The opti is an excellent distributor and does everything it should for most of us and can last a long time PROVIDED you know and address its quirks properly.
As already mentioned, genuine GM opti is the only way to go. I purchased the Accell opti years ago cause it was on sale for $100 and I just wanted to go through it and give it a chance. After disassembling it, the only issue I saw was the 360 degree segmented wheel, a few of the window openings were not very crisp plust the wheel was warped enough that it contacted the optical sensor. The other major issue with it was found after i installed it, there were sparks shooting out of the cap and into the nearby water pump. Clearly the high voltage pats in the cap were not insulated enough to prevent arcing. I quickly concluded Accell opti is junk and I will speculate that the other aftermarket optis (excluding MSD and the other expensive one that is not coming to mind at the moment) are **** as well.
Here are the tips to long opti life.
1. First and foremost, as already mentioned, get a genuine GM opti and convert to vented if your 93 or 94 LT1.
2. As soon as you remove the opti from the box, remove the four funky Torx screws and remove the cap. Remove the two screws and the plastic rotor then remove the metal shield. Now closely inspect the 360 degree segmented wheel for crisp cut windows and flatness. If any of the windows are rough meaning not crisply laser cut or the wheel contacts the sensor when spinning (meaning its warped), return it for another one or cannibalize an old opti for a known good segmented wheel and install it in the new unit. Lastly you want the segmented wheel to ride in the dead center of the sensors mouth as much as possible. This can be adjusted by adding or removing shims provided with the new opti or again cannibalizing them from an old one.
3. Inspect the mouth of the optical sensor and ensure there is no debris or plastic flashing in it, just look at it closely blow it out with air. BTW there is nothing magical about this sensor, all it is is two pairs of LED bulbs that detect pulses from the segmented wheel and send signals to the PCM, thats all. Lastly ensure the insides of the opti are free of dust and debris.
4. Inspect the large round seals on the inner plastic case. If they are not glued into place, this is likely not a genuine GM opti. Ensure the seals look uniform and properly installed.
5. When re-installing the plastic rotor, make sure the screws are loctited and DO NOT over tighten them or the rotor will break apart during use. I use red loctite and have never had an issue removing the screws when the need arises.
6. Inspect the oval rubber seal found on the 4 wire opti connector that plugs into the top of the opti. This seal must be uniform looking and greased with dielectric grease to ensure water and moisture does not enter the opti. This thing should be replaced every year since it can be done in less than 10 minutes.
7. Check the opti for air-tight sealing to keep contaminates out. Hook a mighty vac up to the outlet vent port that normally goes to the intake, plug the vent port normally running to the intake elbow and hold your finger over the large oval opening leading to the sensor. Pump the mighty vac up and if its sealing up tight. If it is, the needle will remain steady which indicates a good sealing opti. If the needle drops, it is not sealed and wherever the leak is you can expect contaminates to eventually enter the opti. Better find and address that leak or problems are in you future.
8. Inspect the connector contacts on the 4 wire harness leading to the sensor for corrosion and clean and re-grease if needed.
IMO when excessive moisture and water that can cause a running issue gets into the opti, it normally gets in at this oval seal in the opti connector on the top of the unit. Over time, this seal will shrink and harden to the point it can no longer seal out the moisture and then you have problems. I have bought replacement seals as part of connector kits on ebay plus they can be found as part of a complete generic replacement connector at any parts house, you just need to swap it from the new connector to the one on the car. IMO its this connector design and the way it installs through the middle case and into the optical sensor, that is the biggest engineering mistake in the opti aside from the knuckleheads not loctiting the rotor screws. I do think the round seals on the inner case do a very good job keeping water and moisture out and I see little value to RTV the seams although I guess it really cant hurt.
The opti is a rather simple yet well performing unit overall and just gets a bad rap IMO in most situations. Like I said you simply need to know how to address its quirks if you are to coexist with it and not hate your car.
7) check the opti for tight sealing to keep contaminates out. Hook a mighty vac up to the vent port that normally goes to the intake, plug the vent port normally running to the intake elbow and hold your finger over the large oval opening leading to the sensor. Pump the mighty vac up and if its sealing tight, the needle will remain steady which indicates a good sealing opti. If the needle drops, it is not sealed and wherever the leak is you can expect contaminates to eventually enter the opti. Better find and address that leak.
Some information before blaming the optical sensor. SES code 16 (low res) and 36 (high res) codes mean the optical sensor detected a bad reading from the segmented wheel (likely moisture or other contaminant in the opti) or there is a intermittent open circuit in the opti harness to the PCM (likely corrosion at the connectors). Like I mentioned above, I have seen warped segmented wheels wear away at the sensor and ultimately cause it to fail and I really believe this happens much more today than in the past. Again the optical sensor is nothing more than 2 pairs of LEDs in a plastic housing and the likelihood of a previously working sensor just up and failing, is very low. Dont believe me, grab a multimeter and perform a diode check on the LEDs if you suspect electrical failure for correct operation.
I suggest anyone considering on dropping huge coin for 24X to try the tips I provided on their current opti first before dishing out the money especially if money is really tight. Yes the 24X is awesome and if it were given to me, I would use it in a second, but then again I never have opti issues.
Lastly I see the opti as being part of the LT1s unique DNA and heritage. That said I dont mind jumping through a few hoops on occasion to preserve it.
I'm aobout to install a mallory IG box, same question, does adding an IG box kill the opti?
My opti has gone bad once only, swapped to a vented one, Delco, and no issues..... yet.
I tried the LT1 MSD coil, didn't last long, went back to stock and its still running. Also had the opti go out before the coil, not sure if the MSD coil caused it.
As already mentioned, genuine GM opti is the only way to go. ]
Ya, Great advise on preventing premature failure!! I have personally done that to 3 GM optis and 1 Chandler opti. The 3 GM opti's lasted 10K miles collectively!! I also went as far as converting to Elect. Water Pump to move it away from the opti a little; Not that it ever leaked!!The chandler is going on 20K now! Why spend $350 on GM unit thats just as likly to fail as any other? A GM mechanic buddy (26 years as GM mechanic) said the opti's are crap! They see them going bad at 40 to 50K on average! GM!!!
All kidding aside, Ive had few issues. Took my GM one off at 100K. Worked fine but bearing wasnt as smooth as a new one,
Put a new GM one in with cam, lasted 20K miles spinning car to 7k and screws fell out of rotor, I may have cracked the rotor on installation, whos knows. Put parts house one in. Cardone I think.
Around 140K Seal on back of opti failed, Filled opti with oil, started cuttin out occasionally. Three months later it died, when I took it apart, it was completely full, no **** COMPLETELY full of oil. Like submerged. Cleaned it out and it still worked but I got another one anyways and installed it.
Keep the oil diver opti as a spare.
I actually havent had an optical sensor that just died and thats what everyone cries about. Overall Im happy with the opti.
Im hard on stuff and Ive come to realize, I have to buy expensive gas and it not gonna last long, and ***** gonna break.
