Cc306 cam.. General question..
Old Nov 1, 2011 | 10:03 AM
defaultexistence's Avatar
Default Cc306 cam.. General question..
The face of the cam where the sprocket mounts.. Do they differ ? Like would a cc306 used in a 95 also work in a 93? Obviously a 93 would use a 93's sprocket...
Old Nov 1, 2011 | 10:07 AM
RamAir95TA's Avatar
You only have to worry about the stock cam - most aftermarket cams have the snout drilled.
Old Nov 1, 2011 | 10:31 AM
Ok thx Joe.
Mike
Old Nov 1, 2011 | 11:49 AM
I guess the dowl shouldn't be an issue?
Old Nov 1, 2011 | 11:50 AM
SS RRR's Avatar
Village Troll
Dowel pin will have to be cut or replaced.
Old Nov 1, 2011 | 11:52 AM
MmmmmmK......
Old Nov 1, 2011 | 03:14 PM
96TransAmboosted's Avatar
on the 2 306 cams i have used the pin would slide right out no problem, then either cut or get a new one the proper size. very easy fix
