Ran a spare 385CI LT1 on the engine Dyno today, stock heads.
We had an S-10 (reg cab short-box) down to 2200# for fun, it had a cammed E-FI LT1 in it and it was a blast!!! at the track we could not get traction to save our lives, butit still ran mid 11s with 2.5 60 foot times (mph was in the 110 range). We sold the S-10 without the engine and put it back in the 97 formula it came from, could barely break 13.5s.....lol
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
A fully professionally ported, expoxied/welded maxed out LT1 head will be lucky to flow what an as cast straight from GM L92 head will flow.
Picked up a built 2 speed glide with a trans break and a scatter shield, I need to build some motor plates for the LT1, and find a small radiator that would work. This will be running down the track sometime this summer with my spare LT1 powering it. Eventually we are going to put a 540 BBC in it, but this is just for fun.
#32
#37
Access panel to the 4link
![](http://i20.photobucket.com/albums/b234/pmr253/IMG_20120329_161132.jpg)
![](http://i20.photobucket.com/albums/b234/pmr253/IMG_20120329_161147.jpg)
![](http://i20.photobucket.com/albums/b234/pmr253/IMG_20120329_155241.jpg)
![](http://i20.photobucket.com/albums/b234/pmr253/IMG_20120329_161139.jpg)
It has strange disk brakes front and back, running 16x33 out back. It has koni and strange adjustable drag shocks. It is setup for a parachute and wheelie bars, but it doesn't require either of them.
#39
Parts list:
radiator scirocco
starter tilton Til-54-20001
distributor msd-8570
headers - probably headman 2" flange adapter
Powerglide deep pan - hughes
fluids (oil,trans, gas)
chrome molly tubing to recert the cage
tires rear 33X16 probably going with goodyears
tires front 24X5-15
fuel cell 5-gal
AN fittings
Digital 6 or better
associated coil
Lexan 3/16"
I have to also pick up all the safety equipment.
New window net, arm restraints, bar padding, belts, and chute.
I still have to pick up all the paint supplies.
radiator scirocco
tires front 24X5-15
fuel cell 5-gal
AN fittings
Digital 6 or better
associated coil
Lexan 3/16"
