Crankcase pressure. Need some insight...
Old Nov 6, 2011 | 04:09 PM
1badzee's Avatar
Default Crankcase pressure. Need some insight...
Hello. Crankcase pressure seems to rise (naturally of course) when I spray the car. I noticed my dipstick tube kind of misted oil on my valve cover a bit. Would I see any benefit with running a breather/filter on the valve cover? I am currently running the stock PCV system (the valve is relatively new and clean) with the fresh air hose going to a canton valve cover (stock location). Nothing special. Any input would be greatly appreciated! I am trying to avoid spending $600+ on a vacuum pump setup OR tearing the short block down and doing properly gapped rings.
Old Nov 6, 2011 | 04:20 PM
stevo9389's Avatar
not really because if you manage to keep the breather from falling off all the time you will pobably notice the oil shooting out of it instead. you could just run a dump tube out the valve cover and down the back of the motor near your exhaust. remember whichever one you do make sure to cap off the rest of the pcv system.
Old Nov 6, 2011 | 04:24 PM
1badzee's Avatar
Hmm... I run a 3" x-pipe setup with bullets before the axles. I would say it is relatively free-flowing. Would it be sufficient enough for a crankcase EVAC kit like the one you are talking about? I could always remove the bullets and just put turn-downs.
Old Nov 6, 2011 | 04:31 PM
Jpack's Avatar
No need to remove the bullets, they flow free enough to use that set up. Are you getting oil weeping at the front seals too?
Old Nov 6, 2011 | 04:39 PM
1badzee's Avatar
Nothing up front. Definitely have a slight weep at the rear main, but that was since I put it in a year ago). It is not enough to be a concern. I am sure the excessive crankcase pressure does not help though. So would the evac be a viable solution?
Old Nov 6, 2011 | 05:54 PM
Jpack's Avatar
There are nay sayers and there are those that actually run them. I run it and I pull 18 in of vac at wot. When I had the engine built by Clayton racing, I was told it would be in my best interest to run it. That was by Jerry Clayton who built top fuel engines for many years. So to me, his word is gold to me seeing the many years of success and records broken by him and his team. The kits have been around many years and on many cars. It's not a gimmick and for the $50 it costs it isn't going to break the bank. Just make sure to install them in the correct locations. They siphon air as it passes through the exhaust through check valves into the breathers in the valve covers. Mine whistle pretty loud. Think procharger sound. I measured vac with a shortridge digital differential pressure meter I use for work. The meter is $2500 and is proof enough for me what they are actually doing.
Old Nov 6, 2011 | 10:06 PM
SRZ's Avatar
SRZ
Only problem I had w/ an evac kit is condensation building up at the check valves causing them to rust if the car sat for an extended period of time. The pass side clogged up completely on me and the clue was I was blowing the oil cap off under decent boost. I just went back to breathers until I pick up one of those high dollar vac kits.
Old Nov 6, 2011 | 10:34 PM
1badzee's Avatar
^ Gotcha, thank you for that input. My car mainly sits and I suppose I could always just unhook the hoses from the check valves to the valve cover caps. Right?
Old Nov 7, 2011 | 09:04 AM
Jerry Clayton's Avatar
or maybe you could just put a droop in the lines so you would have a place for the moisture to collect---you know, kind of like the drain trap under a toilet/sink?
Old Nov 7, 2011 | 10:12 AM
1badzee's Avatar
Gotcha, I appreciate your input!
Would pushloc hose be sufficient to use for this setup? I am using it for my trans cooler lines. I can only imagine it will be fine for this, right?
Old Nov 7, 2011 | 01:04 PM
I use regular heater hose--
also I might add that in my drag car there is oil pressure on one side of the tack and crankcase vacume on the other side----required reading at the finish line every pass---
Old Nov 8, 2011 | 04:02 PM
kgkern01's Avatar
I have WOT crank pressure as well, and I was running breathers, which helped, until oil splash out of the breather onto the header at an autocross race caught fire. For high vacuum, low throttle evac, I left the stock PVC system with an inline air/water separaterI now run hoses from each valve cover, to a T, then into a 22oz catch can with breather on the top sitting in the fender where a CAI filter usually sits. This allows air to come into the system via the breather on the catch can when the PVC is running and then when at WOT, the excess pressure pushes into the catch can and vents out the breather. This way you can vent the pressure the same way that a breather filter does, without any of the oil mist or splash-out that can happen from one just sitting on your valve cover. Everyday that I drive it I usually empty about an ounce of fuel/water that vaporized out. I can post a pic later of my setup if you would like?
Old Nov 8, 2011 | 04:11 PM
1badzee's Avatar
I am definitely open to other ideas. A picture would be greatly appreciated!
Old Nov 8, 2011 | 04:24 PM
kgkern01's Avatar
Ok, I'll take a picture of my setup tonight.
Old Nov 8, 2011 | 04:26 PM
1badzee's Avatar
Thanks!
Old Nov 8, 2011 | 05:53 PM
Jpack's Avatar
Isn't that kind of a bandaid fix though? Doesn't really address the problem at the source.
Old Nov 8, 2011 | 05:57 PM
1badzee's Avatar
Probably. Not sure what the source of the problem could be, but it probably requires time and money lol. If I can find a way to reduce crankcase pressure (for whatever reason mine is that high) I will be satisfied. It is not crazy. Just a small mist out of the dipstick.
Old Nov 8, 2011 | 06:02 PM
tt383lt1's Avatar
CRANKCASE EVACUATION KIT will solve the problem it pull all the presure out of you engine and into the exhaust using the exhaust to pull it and a check valve.
Old Nov 10, 2011 | 11:25 AM
kgkern01's Avatar
Same here, that is why I went with my 'band-aid'. Seems to be working fine for me, and I had more than just a slight mist out of my dipstick.
Here is a pic of my engine bay below. You can see that I have closed 'breathers' (Spectre brand from AZ), that I removed the inner foam and drilled out the 'baffle' from the 1" opening where the breather sits into the valve cover. This made it basically an open flowing item at this point. I then ran 5/8" heater hose from each breather to a 'T' with 3/4" hose coming off of that and into the homemade catch can. The lid of my catch can I affixed a standard filter breather to allow air to flow in at normal cruising, and then pressure to vent out at WOT. So far no dipstick popping out at WOT. You can also see my air/oil separator that I placed inline with the stock PCV breather line from the PCV valve to front of intake.
Here is my homemade catch can (bad pic):
Old Nov 10, 2011 | 12:51 PM
1badzee's Avatar
Gotcha. I appreciate the pictures!
