no oil on 2 rockers
Old Nov 12, 2011 | 03:56 PM
z28_theantirice's Avatar
Default no oil on 2 rockers
Just finished replacing my heads, and fired it up. Runs great, but I noticed on only 2 rockers on the drivers side little to no oil is coming through the push rods on just 2 rockers? I do have great oil pressure everything else is getting oil I'm thinking something may be wrong? Is it typical to not visually see oil on idle
FYI - Lifters are the Caddy or LS7r lifters
http://www.youtube.com/watch?v=tarv1FWhZ8I
Old Nov 12, 2011 | 04:11 PM
Luke1996ta's Avatar
Give it a little throttle and c if u can c the oil then with
the valve cover off
Old Nov 12, 2011 | 04:13 PM
the valve cover off
Yea I tried that, rev'd it as much I could without making to much of a mess, still nothing.
Luke1996ta's Avatar
Did u happin to change lifter?
Old Nov 12, 2011 | 04:15 PM
Nope, same lifters that were in the car when I pulled the heads.
Luke1996ta's Avatar
I would say u have two bad lifters
Old Nov 12, 2011 | 04:50 PM
defaultexistence's Avatar
I would say you have different preload on those two lifters , and lifters are quite simple inside .. When people say lifters are bad when not pumping oil.. from my experiences the oil passages are clogged and just need disassembled and cleaned..
Old Nov 12, 2011 | 04:54 PM
So you think its worth re-doing the preload on those 2 lifters and see if I get an oil up top? If they don't produce any oil again then they need to come out?
Old Nov 12, 2011 | 05:29 PM
96TransAmboosted's Avatar
I would change all the lifters at once if
They all have the same amount life. Of there new maybe there duds. I had 2 bad lifters myself.
Old Nov 12, 2011 | 05:38 PM
All lifters are of the same age. 4 years old, probably under 10k in mileage.
Old Nov 12, 2011 | 05:44 PM
transbird95's Avatar
How long did you let it run? It can take a while for oil to get up there.
Old Nov 12, 2011 | 06:01 PM
I've let it run for probably 5+ minutes now.
Old Nov 12, 2011 | 06:10 PM
Give it a Little more preload
Old Nov 12, 2011 | 06:24 PM
97Z28SS's Avatar
New pushrods or did you re-use them also, if so did you make sure they weren't clogged? I use a can of brake cleaner with the straw and spray thru each pushrod to make sure non are clogged.
Old Nov 12, 2011 | 06:27 PM
ok I have had to run them at least that long to get oil to the top. But most of the time the lifters were new and had to pump up yet.
Old Nov 12, 2011 | 06:33 PM
mud.man.rj's Avatar
Run those 2 a bit looser for a few minutes to take the load off of them and they will oil, probably collapsed them to much and won't pump up with the load. Had it happen, run a bit loose then when oil starts adjust normal preload running and all good. If not the disassemble lifters as mentioned and clean.
Old Nov 12, 2011 | 06:34 PM
Luke1996ta's Avatar
I always soaked my lifters in oil over night before putting them that way there is oil in them as soon as the motor starts
Old Nov 12, 2011 | 06:37 PM
I'll give this a try tomorrow AM. As far as I know they were fine and pumping oil before I took everything apart. (fingers crossed you are right)
Old Nov 12, 2011 | 06:46 PM
mud.man.rj's Avatar
Letting them soak dosn't always work though. You will get it worked out.
Old Nov 13, 2011 | 10:48 AM
lossen them up and see if oil starts shooting out, then slowly start to tighten them back down, if you get no oil when you reach zero lash then i would say remove the 2 lifters take them apart and clean them. reinstall and try again. If they dont work after that then there no good. you can get 2 lifters at bumper to bumper for like 17 ea
