358 ci lt1?
Old Nov 13, 2011 | 06:21 PM
autolabs_vero_beach's Avatar
Default 358 ci lt1?
This is was i have to work with.
Lt1 95k miles no problems with motor.
Le2 package with cam
Lt headers
4l60E stock 3500miles
mail order tune for the mods.
I want to convert it to carb, and want ideas about making it a 358ci if possable,.I want to rev 7.5k-8k and want 10.8:1 compression.
Power goals 500hp
Do able with $4k buget?
Old Nov 13, 2011 | 06:22 PM
RamAir95TA's Avatar
No...
Old Nov 13, 2011 | 06:25 PM
Dave357LT1's Avatar
Are le2's on the motor? Just do arp rod bolts on ur motor with those heads. Why go to carb? Le 2's would be fine right at 7k.
Camaroking1996's Avatar
No way in hell you are getting 500 hp with a 4k budget.
Old Nov 13, 2011 | 06:32 PM
well at least a start, its a project car. so if the cars don for 4-6months doesn't bother me.
4k to start me out. thats what i have in hand
Old Nov 13, 2011 | 06:34 PM
Why do u want to spin so high rpms?
Old Nov 13, 2011 | 06:47 PM
96capricemgr's Avatar
and why such low compression?
my motor revs up pretty fast. just want some more rpms.
i also start hitting rev limiter at 134ish in overdrive
4.56 gears in a 10 bolt rear end.
Old Nov 13, 2011 | 06:49 PM
lt1slowz28's Avatar
lets just say, most of my short block cost was a little over 4 grand...
Old Nov 13, 2011 | 06:50 PM
eh. i would but 93 is about the best i can find within 20ish miles
Old Nov 13, 2011 | 06:55 PM
only thing i'm not doing myself is machine shop stuff
Old Nov 13, 2011 | 06:56 PM
why would u have 4.56 gears in a ten bolt?
lt1slowz28's Avatar
daily driver as well?
Old Nov 13, 2011 | 06:58 PM
lt1slowz28's Avatar
set some realistic goals with your budget... machining alone can cost ~ 900 for a reliable set up... parts, go fish; rotating assemblies are usually 1800 or so depending on how wild you wanna get. not to mention everything else that nickel/dimes you to death.
Old Nov 13, 2011 | 07:02 PM
it's not going to be a daily, just a to meets and some action at the track.
Old Nov 13, 2011 | 07:04 PM
i knnow its going to nickel and dime me to death mainly becus it's a lt1 lol.
but i can make more money, just starting out.
Old Nov 13, 2011 | 07:05 PM
transbird95's Avatar
how do you use a mail order tune if its carbed?
EDIT.... Never mind read it wrong saw you already had that.
If you want to run 500 hp safely, upgrade the rear end quickly. The stock, soft 10 bolt will explode the first time u try to launch it.
Old Nov 13, 2011 | 07:09 PM
LTX's Avatar
LTX
9" inch
Old Nov 13, 2011 | 07:11 PM
i was thinking a 9inch ford rear end
