im stumped, dying problem
Old Nov 18, 2011 | 09:16 AM
nintythreez28's Avatar
Default im stumped, dying problem
this is the second time in about a week i was coming home and suddenly when i hit the gas my car chokes out, if i let off it just idles rough, but will eventually die out. it starts righht back up and im on my way but i know my car isnt randomly suppose to die... what is goin on here. after the first time i replaced the coil to a msd coil... thatsnot it. suggestions? want my car to stay running when driving!!!
Old Nov 18, 2011 | 09:21 AM
RamAir95TA's Avatar
Check your fuel pressure before anything else.
Old Nov 18, 2011 | 09:50 AM
What is the easiest way to accuratly find fuel pres? Also what is the normal fuel pressure?
Old Nov 18, 2011 | 11:20 AM
RamAir95TA's Avatar
You'll need a fuel pressure test gauge available at most auto parts stores (around $30). Make sure you get a high pressure gauge with a screw-on connection.
With the key on, engine off pressure should be right around ~43psi and hold steady.
Old Nov 18, 2011 | 12:05 PM
Ok ill check it out and get back with ya thanks
Old Nov 18, 2011 | 01:07 PM
mguidry629's Avatar
Use the schrader valve on the fuel line. On your 93 it will be on the drivers side between the intake and valve cover. You should be able to shut the hood and have the guage by your windshield wipers and view it while driving.
I would also check your opti harness and check for any stored codes in your computer. I assume the SES light hasn't come on. It can throw codes without triggering the SES light on the dash.
My opti harness connector that plugs into the opti had a broken clip (common) and it would jar loose and kill the car.
Let us know when you've ruled all that out.
Old Nov 18, 2011 | 03:05 PM
as far as codes i know its throwing one for QDM1 which is something for the fan relay but i will check the opti harness. do you have a pic of the blug that commonly breaks
