Diagnostic head-scratcher
I've got a 95 Camaro LT1, essentially stock. My issue is that it runs just great; fires up no problem, no misfires, and pulls really strong. However, after driving the car for 15 minutes, it cuts off! It will do this methodically within a minute or two either way. Once it dies, I have to let it sit for 20 minutes or so before it will start. Once I wait, I'm good to go again without any drivability issues. I haven't really pressed the issue to see how far I can go after the first time it dies.
I'm hoping that posting this will find someone that had the same or similar issue and can guide me down the right path. If you need to know any more particulars to help me solve this, please ask. HELP!
possible ICM heatsoak, but if it starts up and runs again no problem it could be a stored code for the ECT, on the waterpump... try and disconnect that and drive around, should force the car into limp mode.
lt1slowz28, I was thinking along your lines, since it seems like the car needs to 'cool off' and then it fires no problem. Kinda like the weak window motor everyone has seen. But since I work for an auto parts company, and the parts themselves are cheap, I went ahead an threw a coil and module on there. That's not to say they aren't bad, so I'll check there too. I have a scan tool that can see stored codes and none were present. In fact, I've never seen the light come on since I've owned the car. As far as the temp sensor, I didn't know that would keep the car from running! But what it sounds like you're telling me is if it won't run, I may be able to unplug its connector and force it into limp mode? Hmmmm.
These leads you guys have given me are great and I really do appreciate it. I'm off to work in a few minutes, so if you or anyone else have more possible solutions, fire away. I'll try these out as soon as I'm back home.
And here's some spark help
http://shbox.com/1/4th_gen_tech2.html#opti_test
Makes it easier yet.Al 95 Z28
