dead battery on my 96 ws6
Start on a high scale and work your way down. Be sure EVERYTHING is off and the doors are closed.
http://www.youtube.com/watch?v=yFCT-YZbU5o
He removes the positive cable, but it's safer to remove the negative. The test is the same. Black wire from the meter to the battery post, red to the cable. The normal current drain with everything off should be less than .2 Amps or 200 MA.
Al 95 Z28
Would really help to know what your meter showed. That would rule out lots of stuff. I usually check things like the lamp in the glove box and so on. You can usually tell by opening the lid and seeing if the bulb is real hot.
Al 95 Z28
