Yep, I've got more problems...
Old Nov 28, 2011 | 10:41 PM
FocusVince's Avatar
Unhappy Yep, I've got more problems...
Ugh, well I have an idea of what the problem is but I want some second opinions...
Yesterday I was driving home from work and all of the sudden I noticed that the car seemed louder and lost a lot of power. Under acceleration the exhaust sounds the same but somehow the engine seems louder. There is a lot of shaking under acceleration now and it seems like a lot of random noises too. I am almost positive that its the motor mounts (I need to get them done anyways..) but would they really get this bad, this fast? Just a few days ago the car was driving great and had plenty of power, and now its just barely drivable...
I also feel like it could be spark plug wires (again). Any opinions, I am getting really sick of these "little" issues.
Old Nov 28, 2011 | 10:54 PM
tt383lt1's Avatar
is there any codes on. and i wont think motor mounts would make it so you lose power. any other syptoms
Old Nov 28, 2011 | 10:58 PM
FocusVince's Avatar
No codes, I don't know if its a loss of power, as much as maybe its not putting down power. When I accelerate there is a lot of shaking though..
Old Nov 29, 2011 | 08:03 AM
vtec's Avatar
Resident Racing Jerk
louder intake sound and loss of power makes me think clogged cat... but that wouldnt cause shaking.
Old Nov 29, 2011 | 09:41 AM
FocusVince's Avatar
There is no cat
Old Nov 29, 2011 | 10:21 AM
ahritchie's Avatar
codes?
Old Nov 29, 2011 | 10:59 AM
FocusVince's Avatar
No codes, I'm going to get under the car and check the mounts and see if anything doesn't look right...
Old Nov 29, 2011 | 11:22 AM
ahritchie's Avatar
If it is your motor mounts, you will hear all kinds of noises, exhaust, metal on metal banging ect (messing with your knock sensor?) Mine were shot and it didn't put down the power like it should and you could heard thumping when shifting gears/accelerating. Could have messed up wires or burnt them with all the extra movement with the motor in the engine bay (just a guess). Get that fixed first and go from there.
Old Nov 29, 2011 | 11:32 AM
defaultexistence's Avatar
I'll start the bidding at $1,000
Old Nov 29, 2011 | 02:46 PM
FocusVince's Avatar
Something is really wrong...the engine isn't shaking at all, the car barely accelerates and the exhaust note has definately changed...maybe its the damn wires again, but the car is running worse that it ever has before, its VERY bad...
Old Nov 29, 2011 | 03:01 PM
FocusVince's Avatar
well I went out and started up, and I'm getting a little bit of white smoke...which would sound like a head gasket, would that cause a huge power loss?
Old Nov 29, 2011 | 03:06 PM
the_merv's Avatar
Ya if you popped it you would lose power and have a mis-fire. Does the smoke smell sweet?
Old Nov 29, 2011 | 03:10 PM
jaycenk's Avatar
Water being injested constantly from said bad head gasket and hydro locking the rings. stop driving it. check water level. check the oil to see if the oil level has gone up or if it smells like coolant. Do the basics. We can throw a thousand scenarios at you but maybe one will stick. The info you are giving is a symptom not the problem so you need to dig in and see what it is. Check everything you have touched recently.
Old Nov 29, 2011 | 03:18 PM
FocusVince's Avatar
yeah I hear that...I smelled the exhaust and it doesn't smell right...I don't know what burning coolant smells like but I feel that the white smoke is a dead give away, and the smoke was still there after running for a few minutes.
Old Nov 29, 2011 | 03:22 PM
the_merv's Avatar
It should smell sweet..like hot coolant.
Old Nov 29, 2011 | 03:28 PM
jaycenk's Avatar
Yea you will smell the destinct smell of coolant even if your exhaust is already smelly from a cam and no cats.
Old Nov 29, 2011 | 04:04 PM
FocusVince's Avatar
I'll check again later, its tempting to go all out and do gaskets, valve springs, roller rockers, etc. but that would cost way to much.
Old Nov 29, 2011 | 04:07 PM
Could still be a heavily misfiring cylinder loading up from a burnt wire..
Old Nov 29, 2011 | 04:21 PM
FocusVince's Avatar
I'm not ruling that out either haha
