24x coil mounting question
Hey guys im going to be using the eficonnections 24x system on my 427 build. And need to know how you guys with PARAMETER bolt valve covers are mounting the coils.
the brackets they sell on their site say there for center bolt valve covers only
Some people mount them under the cowl or on the subframe. I don't have any pictures as I have center bolt covers and made my own mounting method. Hopefully someone who has done the other two places chimes in.
Not sure what a Parameter is, but Perimeter would be a bit tougher, you may want to look at hiding them under the cowl. Most the LT1s including whats left of mine that run this set up, use center bolt valve covers. Be a lot cleaner to stick them under the cowl, another guy on here with a YSi Lt1 mounted them on the back of his single plane which you couldn't do since your a Gen I and will whats left a distributor back there.
You could weld threaded bosses to the center of perimeter valve covers to accept the coil brackets. Check out http://www.aluminumspacers.com for threaded aluminum spacers. Not sure where to suggest steel threaded spacers.
