THE CHEAPEST way to retard timing
Old Oct 30, 2013 | 05:53 PM
fex77k's Avatar
Use a box to pull timing. or take it from the tune.
Old Oct 31, 2013 | 11:18 AM
Stroked96Bowtie's Avatar
MSD Digital 6 homie, don't go cheap. Dig6 worked great in my car, set the retard to happen when 12v is applied to the solenoids. Good and correct ignition is one of those critical things to get right. GL
Old Nov 1, 2013 | 07:17 AM
moehorsepower's Avatar
[QUOTE=96capricemgr
There is a "professional" tuner that has repeatedly been caught setting timing over 40degrees at WOT sometimes with AFRs over 14:1, you spray a 100shot on that and you will likely have a problem.[/QUOTE]
I think I have seen his tunes, I have seen in the mid 50 degrees in the midrange from a certain tuner.. and as said, depending on the tune, I have seen 150 shot on stock tune and survive then I've seen damage on only a 100 shot.
