THE CHEAPEST way to retard timing
Old Dec 2, 2011 | 06:20 PM
my number 1 hater's Avatar
Default THE CHEAPEST way to retard timing
What is the cheapest way to retard timing, 94 LT1 on spray? Anything UNDER $100? It just needs to retard the timing thats it.
Old Dec 2, 2011 | 06:46 PM
nitrous2fast's Avatar
How much spray?? if a 100 shot or under no need to retard the timing...
Old Dec 2, 2011 | 06:48 PM
rich5368's Avatar
Mallory box
Old Dec 2, 2011 | 07:24 PM
MikeFSKSpeed's Avatar
I have the MSD 8680 Boxes in stock if needed. Great product and $135 + shipping
Old Dec 2, 2011 | 09:23 PM
Originally Posted by nitrous2fast
how much spray?? If a 100 shot or under no need to retard the timing...
150-200
Old Dec 2, 2011 | 09:25 PM
I think you need an IGN box for that?
Old Dec 2, 2011 | 10:11 PM
have you upgraded the ignition at all??
any ic box that has a retard function on it will suffice.... you're probably looking at $150 minimum for a used piece..
Old Dec 2, 2011 | 10:21 PM
tt383lt1's Avatar
i have a mallory 667c box i will sell for 125 shipped and it works fine i used it on my lt1 motor than i switched to the 24x conversion and it wont work any more for my engine.. i has 3 built in nitrous retards just ground a wire out and it will retard it. and it has a controller so you can controll it in the car.. it work awsome here is a link for it
http://www.ebay.com/itm/Mallory-HyFi...item5ae39b1bd9
Old Dec 3, 2011 | 03:23 AM
gregrob's Avatar
Cheapest is to leave it stock...
You could also buy a 60 dollar cable and pull timing in the tune ...
Old Dec 3, 2011 | 07:49 AM
trilkb's Avatar
How true is this statement? What about a car with a cam and bolt ons?
Also, how safe is this statement?
Old Dec 3, 2011 | 10:08 AM
05HD's Avatar
The answer to your specific question "the cheapest way to retard the timing" is a resistor for the air temp sensor so the PCM thinks it is 100 degrees hotter than it really is ambient. Last I checked Radio Shack had them around 4 for $1.
Old Dec 3, 2011 | 10:10 AM
pancho toco loco's Avatar
^^^^ I'd always wondered that to.. I would say with a set up like your car or even something like my car being a bolt on with a tune we would need a separate no2 tune. I dont think running cooler plugs and retarding the timing will be surfice
Old Dec 11, 2011 | 08:20 AM
Originally Posted by tt383lt1
i have a mallory 667c box i will sell for 125 shipped and it works fine i used it on my lt1 motor than i switched to the 24x conversion and it wont work any more for my engine.. I has 3 built in nitrous retards just ground a wire out and it will retard it. And it has a controller so you can controll it in the car.. It work awsome here is a link for it
http://www.ebay.com/itm/mallory-hyfi...item5ae39b1bd9
pm sent
Old Dec 11, 2011 | 08:31 AM
Really, no way around cheap. Seems like there would have been an open place in the market for a cheap timing retard (when these cars where hot). The only cheap way is the resistor mod (im not fan). So the alternative is a used box, and its a good upgrade for an LT1.
Old Dec 12, 2011 | 07:23 AM
96TransAmboosted's Avatar
Cheap is never smart when it comes to cars. I want a cheap way to blow my pistons apart on a 150-200bigger shot of nos. I will yell you right now that on a 125 shot and up if you don't read plugs and adjust the retard the car is going to run like **** in the upper rpm on the nos. The best bang for the buck would be either a digital 6 msd or the mallory box posted. This will give you the ability o find what your engine likes. If not you will likely blow spark out and send some parts out via the oil pan real quick.
Old Dec 12, 2011 | 08:58 PM
Picked up the 667c box.. Im good to go.
Old Dec 15, 2011 | 07:10 PM
SexyTransAm's Avatar
^ this!
Old Dec 15, 2011 | 08:20 PM
97Z28SS's Avatar
MAF Translator Plus has timing retard for N20 and it's plug and play, no wire cutting or splicing and I have one for sale brand new never used. Here's some pics
http://i1110.photobucket.com/albums/...forsale002.jpg
http://i1110.photobucket.com/albums/...forsale001.jpg
http://i1110.photobucket.com/albums/...forsale005.jpg
Old Oct 30, 2013 | 12:26 PM
rlabar01's Avatar
Exclamation im in the same boat
i like the mallory box but the msd 6al with a timing box is nice too anyone have these items still for sale? vendors?
i have a 94 lt1 doing a wet 150 set up i dont want to spend a ton of money but i know this stuff isnt cheap either.
whats the easiest user friendly ways to pull 3-4 degrees on these motors only when spraying either manually or automatically?
Old Oct 30, 2013 | 05:10 PM
96capricemgr's Avatar
Mallory 685 is probably the best combination of cheap easy and automatic.
I know this is an old post BUT I still think it odd I didn't see anyone ask how the car was setup before he wanted to pull timing.
If someone has a bolton car with stock programming I would just put 92-94 octane in, stock programming is for 91 octane and safely conservative, little extra octane and a modest shot should be nice and safe. If he had an aggressive tune tune though then it would be prudent to look to dial it back some.
There is a "professional" tuner that has repeatedly been caught setting timing over 40degrees at WOT sometimes with AFRs over 14:1, you spray a 100shot on that and you will likely have a problem.
