Best headers gaskets??
Old Dec 7, 2011 | 08:50 PM
96capricemgr's Avatar
Lots of gaskets listed will work.
Best I have used is the Earl's Ptessure Master. Bet the sealing material is similar to the Remflex discussed above but the Ear's is an aluminum frame that holds inserts.
Old Dec 12, 2011 | 05:47 PM
carlos8's Avatar
hey gys just want to make sure are these the percys gaskets??
http://www.summitracing.com/parts/PHP-66031/
Old Dec 13, 2011 | 10:04 AM
96TransAmboosted's Avatar
Default why buy a gasket you can only use once when there are gaskets out there for the same price that can be reused? The stock MLS gaskets work great im not sure why most disgaurd them and by a felt pro ect. MLS gaskets can be reused in most cases and that's one of there benefits aside from being very hard to blow out.
Im not attacking the reflex either they were a good gasket, and when a few bolts came loose here and there they did reseal. But removing them was a pita and scrapping the head and headed clean after was also a pita.
Old Dec 13, 2011 | 11:10 AM
RamAir95TA's Avatar
I think it's hilarious that there were a dozen recommendations for the 1406s by Felpro, but the OP is going with something else.
