Pulley Removal
I put the puller on it and cranked it until I thnk it started to bend the pulley. Upon closer inspection I am unclear if the pulley goes over the crank snout or not. Yes it s nasty because of the leaking seals and I will clean it all when opti is removed and seals replaced.
Any have one of these underdrive pulleys and know how they go on?
Thanks.
I tried a smaller bolt in the center and pulling against it. I bent the bolt. I will get a grade 8 and give it a try. Does anyone know the size of the crank bolt? I think jury rig Joe worked on ths thing it only had 5 bolts on the water pump!
Isn't this some crap! A damn pulley!
Thanks for everyones help just a weird one.
