Got my fuel pressure reading...
Old Dec 10, 2011 | 10:23 AM
FocusVince's Avatar
Default Got my fuel pressure reading...
..for those who didn't recheck the previous thread. It was staying around 40 psi and when I tried to start it it didn't change. The car will start and instantly cut off, after a few tries it will idle very low to the point that its barely running, it won't go above 3000 rpms, it runs very rough up to that point.
I've pretty much given up at this point, I know it could probably be a bunch of things, what does it sound like to you?
Old Dec 10, 2011 | 10:33 AM
lt1slowz28's Avatar
go to your old thread and post this...
Old Dec 10, 2011 | 10:36 AM
FocusVince's Avatar
I did. 3 times.
Old Dec 10, 2011 | 10:40 AM
ZFreie's Avatar
Still have cats on the car?
Old Dec 10, 2011 | 10:47 AM
FocusVince's Avatar
No sir. No cats. Long tube headers. New coil and wires.
Old Dec 10, 2011 | 12:05 PM
96TransAmboosted's Avatar
MAF sensor could be messing up. Hard start wont rev..... all could be related. No codes ect?
Old Dec 10, 2011 | 12:21 PM
FocusVince's Avatar
Its a 93 so no MAF. Could it be the optispark? The only code I got was code 46 (four flashes, pause, six flashes.) which is the VATS system.
Old Dec 10, 2011 | 12:25 PM
Go to shobox web site and do the options wiring test to make sure all is well. It might point you toward the coil pack or options who knows without diagnosis. You need a Dvom to the test it all.
Old Dec 10, 2011 | 12:53 PM
lt1slowz28's Avatar
bad map sensor and or wiring?
try to trace down EVERY SINGLE wire and sensor to see if they are damaged, burnt or cracked....
Old Dec 10, 2011 | 01:37 PM
FocusVince's Avatar
Alright I'll go over all the wiring and hopefully that will be the problem.
Old Dec 10, 2011 | 03:03 PM
96lt1m6's Avatar
You may have a bad ICM ignition control module
Old Dec 10, 2011 | 03:21 PM
95mysticta's Avatar
All of the things mentioned can cause some messed up stuff. A bad Temp sensor in the waterpump can also cause hard starts and misfires. Check the reading of the temp sensor with a scantool when its cold to make sure its the same as the actual outside temp. If its not even close then time for a new one.
Old Dec 10, 2011 | 03:27 PM
FocusVince's Avatar
I wish I had a scantool but I'm guessing those are expensive. Maybe I'll just replace it anyways if this wiring check doesn't work. It seems like it could be just about anything on the car causing this.
Do you have any suggestions on a scantool?
Old Dec 10, 2011 | 04:08 PM
93 LT1 Vette's Avatar
shotguning parts will kill your pocket book and your morale. I can tell by your posts your about done. Limp it down to nearest Vo-tech school and ask them to scan it for you. Chances are they will be more than happy to help.
Old Dec 10, 2011 | 04:10 PM
Again all these suggestion are just a guess.
He needs a meter and a diagram so he can test it all. Content get me wrong a good visual test is a good start but a meter will yell you exactly if you DO or DO NOT have an issue with wiring and point you in a good direction.
For instance car was running great no problems. Im decided to wire tuck the engine bay. Go to start it and would kinda start sometimes at a rear low idle 300 or so.
Other times would start right up and could tell it was not 100% and once warmed up would not rev and if stalled would not restart. I would think that since I just tucked the wires it must be wiring right?
Wrong instead of jumping the gun and tearing everything apart I got out my meter and starter probing. In less the 1hr had it figured out to a shorted coil pack. What most don't understand when reading a forum like this is, you can not read a thread or guess what the issue is without testing and diag. Way cheaper then buying parts and not ridding the issue the first time.
Fixing the issue sorry my phone sucks.
Old Dec 10, 2011 | 04:15 PM
Best advise yet +1. Hey Boost any recommendations on a good mutual fund. LOL.
Old Dec 10, 2011 | 04:37 PM
FocusVince's Avatar
That's good advice. I am not sure what I'm supposed to do though? Am I supposed to go buy an OBD1 scanner and see what the engine is doing? Or do I get a multimeter (I have one) and check all the wiring and circuits?
If you have a link to what I'm supposed to check and how to do it that would be great.
Another question I have is that I have new spark plugs in the car and they are gapped at .55 They are NKG v power copper plugs (I believe the same or similar to the TR55's). Could these somehow have gone bad and be causing my issues? Is the gap wrong? Just a side question I thought I would ask.
Old Dec 10, 2011 | 04:53 PM
IronOutlaw's Avatar
I would use the multimeter. Go to shbox's site and it will tell you what to do.
I kept my plugs at the gap they came in. Seems like they were the tr55 and Gapped at .044
Old Dec 10, 2011 | 05:31 PM
FocusVince's Avatar
Mine were pregapped at .60
And I'll check shbox's site
