Fuel level is off on gauge cluster.
Old Dec 17, 2011 | 09:25 AM
whytryz28's Avatar
Default Fuel level is off on gauge cluster.
Ever since i've owned my LT1 the gauge has always read
1/2 tank = Almost empty
Full tank = Half tank
Way off the gauge = Full
Any ideas why? I pulled the unit when I installed my 255 pump and nothing looked to be broken.
Old Dec 17, 2011 | 09:31 AM
andrew ws6's Avatar
your not the only one I think most of them are close to that, I get about 280 -300 miles to a tank and from 1/2 to E iget laki 50 miles
Old Dec 17, 2011 | 09:42 AM
93BlackZ28's Avatar
Pretty sure they're all like that.
Old Dec 17, 2011 | 09:59 AM
whytryz28's Avatar
wtf lol its so annoying. My friends 94 wasn't but he had about 80k on the body.
Old Dec 17, 2011 | 10:05 AM
bigj2717's Avatar
Yeah that's normal because of the shape of the tank
Old Dec 17, 2011 | 10:11 AM
whytryz28's Avatar
There is no way these things rolled off the factory with shity fuel gauge levels.
Old Dec 17, 2011 | 10:18 AM
andrew ws6's Avatar
yea I bought my fist T/A in early 99 it was a 96 with 30k on it it was the same then as the 96 I have now.
Old Dec 17, 2011 | 10:19 AM
96TransAmboosted's Avatar
Maybe you snagged the fuel level arm when you installed the walbro and now the values are all out of wack. I had to replace my fuel level sensor a few years back because the wires at the very top got hot and would short out. I new gm had issues win the grey and purple wires doing this all the time. Since I replaced it the gas gauge reads much closer until it hits 1/4 tank.
Old Dec 17, 2011 | 10:36 AM
RamAir95TA's Avatar
This has been one of the most common and notorious problems with the LT1 f-body since it came out in 1993. The level sender only measures the level in the tank and since the tank itself is shaped like an upside down triangle there's less in the bottom and more in the top.
Short version, you're going to just have to deal with it.
Old Dec 17, 2011 | 11:45 AM
shbox's Avatar
Way.
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Old Dec 17, 2011 | 12:03 PM
FormulaJoe's Avatar
My gauge is the same way.
Old Dec 17, 2011 | 12:08 PM
Sk8phreak88's Avatar
Yep, same as everyone else..
Past Full= Full
Full= 3/4
3/4= 1/2
1/2= E
E= get your *** out and push.
Old Dec 17, 2011 | 02:05 PM
FocusVince's Avatar
Did anyone ever develop a fix for this issue? Not that it bothers me, I've grown used to it and its the least of my concerns right now anyways.
Old Dec 17, 2011 | 02:40 PM
riceburnerZ28's Avatar
My gauge does the same thing. Once the needle hits the full mark I start heading for the gas station. Before I installed my walbro the gauge was very accurate so I think it may have something to do with the fuel level sensor.
Old Dec 17, 2011 | 03:07 PM
whytryz28's Avatar
My gauge always read this way, even before the pump swap.
Old Dec 17, 2011 | 03:13 PM
01z's Avatar
01z
lol mine was the same way, also low coolant sensor..............
Old Dec 19, 2011 | 09:17 AM
IrocZ's Avatar
My car does the same thing after I installed my walbro. I'm sure we touched something we shouldnt have while installing it cuz it use to work perfectly before that. I've not looked at it since i've just dealt with it.
Old Dec 19, 2011 | 10:14 AM
jaycenk's Avatar
Mines actually fairly close. It's about an 1/8 off. It's a 97. The 93 we had was way off. Used to always run out around 1/8 to 1/16th before E.
Old Dec 19, 2011 | 10:19 AM
metalmilitia606's Avatar
Mine does it. I think it is an fbody thing.
Old Dec 19, 2011 | 11:20 AM
sweetbmxrider's Avatar
Its very simple to fix. Take apart your dash, remove the plastic cover over the gauges, take a fork and pop off your gas needle, go fill up to the absolute max, pull off to the side and with the car running for a couple minutes reinstall the needle on the F mark.
Problem? Solved.
