LT1 WS6 2 tubes where to go???
Old Dec 20, 2011 | 03:07 PM
gregfire's Avatar
Default LT1 WS6 2 tubes where to go???
Hi I got 2 tubes detected who are not connected.
I got a code who says secondary air injection.
the car is starting not right away. after 2 to 3 sec it starts.
dont know if this has something to do with that 2 disconnected airhoses at the drivers side engine compartment.
both tubeconnectors fit togehter but the one above is far away positioned so i dont know..
please see pics. just bought the car so i am getting to know it first.
its a 96 LT1 WS6 Trans Am.
thanks
Greg
Attached Thumbnails LT1 WS6 2 tubes where to go???-pc200095sm.jpg   LT1 WS6 2 tubes where to go???-pc200097sm.jpg
Old Dec 20, 2011 | 03:12 PM
my number 1 hater's Avatar
FIRST PIC: OPTI vent to air intake elbow or tube.
Second PIC: might also be OPTI but its had to tell.
Old Dec 20, 2011 | 03:22 PM
gregfire's Avatar
ok thanks
i got the ws6 ram air box there is hole open with no rubber inside anymore
thats where that one goes probably. thanks
driving like this , has this any change in the performance or codes ec??
Old Dec 20, 2011 | 03:26 PM
DAVE00's Avatar
Originally Posted by gregfire
ok thanks
Put the blue elbow in the hole on the side of the intake boot. You will have a bit of performace decrease as you have a vac/unmetered air coming in that hole. As to the second pic, that hose looks to go to the AIR pump/solenoid, however I'm unsure as I don't know the setup on 96' and OBDII cars for the Air injection/pump. Are you getting any SES lights?
Old Dec 20, 2011 | 04:23 PM
gregfire's Avatar
yes PO410 Air injection system fault
i got the blue elbow in that hole.
first i thought it goes into the air housing. i had a big open hole on that housing, nothing inside!
i closed it temporarly. on the driver side of the housing.
the other hose from above is hard to tell.
thanks
Greg
Old Dec 21, 2011 | 09:07 AM
gregfire's Avatar
here is that open port. i temporarily closed it with tabe.
driver side port airbox ws6. the other side thas the air temp sensor.
but that side was totally open!? cant find any cabel or socket for that in my engine compartment.
thanks
greg
Old Dec 21, 2011 | 09:04 PM
96Formula6spd's Avatar
thanks
greg
Thats the hole to the air pump hose. Should be a hose from that to the air pump. That could be why your throwing a code. Check the air pump and see if has an opening on it for a hose that size. If its there put the hose on.
Old Dec 21, 2011 | 09:58 PM
gregfire's Avatar
damn, i hate owners who dont care for her Trans Ams!
i checked the air pump. there are actually two ports for hoses?
yes thats probably my code PO410
thanks
Greg
Old Dec 22, 2011 | 12:16 AM
thanks
Greg
No Problem man. Say that and knew what it is. I will have to cap mine off since the air pump is gone when I install my ws-6 box.
Old Dec 22, 2011 | 06:39 PM
gregfire's Avatar
got another port with no connection.
on the passenger side engine. dont know what part that is
does it go anywhere? the hose is open!!
got a 96 WS6 Trans am with the Ram Air box.
thanks
Greg
Attached Thumbnails LT1 WS6 2 tubes where to go???-pc220102sm.jpg   LT1 WS6 2 tubes where to go???-pc220103sm.jpg
Old Dec 22, 2011 | 06:56 PM
jkicak's Avatar
i think the last one you posted is just a vent hose with no connections.... should be ok there.
check out this page for lots of pics and exploded views. it will help a LOT with issues like what you have!
http://shbox.com/1/4th_gen_tech1.html
Old Dec 22, 2011 | 06:58 PM
Yeah that one does not go anywhere. Its a vent or drain. But its fine as is.
