Trap Door Mod - Cut off wheel without Sparks.
You would have a heart attack then if you would have seen how many times I cut the body lines of my 69' Camaro to get the wheels to fit.
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I just put a new fuel tank and pump on my car. Removing and installing the tank is a much bigger pain in the a$$ than it should be. Maybe it's easier if you have a lift, but with only jacks and jackstands, I considered pushing my car into a sinkhole. The only thing that stopped me was that I didn't have access to a sinkhole.
Having said that, I'm one of those **** guys that has a problem with cutting a hole in their car.
I have ALWAYS replaced the pump the correct way,generally taking me 1.5 hours on the ground and roughly 1 hour on a lift...... Cannot honestly say how many pumps I have done since 1988(had my own shop) however I have owned a bunch of f-bodies and have only replaced 4 defective pumps so I do not see the need in cutting the floor.....
********SIDE NOTE********
If I was stuck on the side of the road with a dead pump I would damn sure appreciate having the access panel!!!
With that said I would cut the hole harms/weakens nothing at all
#34
#35
They probably did feel the same way, which is why unmolested first gens go for so much. That said, the cars from that era are different. I don't honestly believe there will ever be cars worth as much to as many people again. And at any rate the lt1 cars will always be the reheaded stepchild.
#36
No they aren't 69 z28s but I see potential.....maybe it will be just because of the engine...maybe it wont....either way I don't care cuz that just means I wont have to worry about breaking the bank to get one
#39
#40
I dont see potential in these cars, the first gens are rare because get this... That body style was produced for 3 years only and even then each year looked different. and got a complete make over for the 70 style.
