MSD What exactly does it do?
Old Mar 16, 2004 | 03:33 AM
TSAEB's Avatar
Default MSD What exactly does it do?
Ok ...sorry for the question but can someone explain to me what exactly does a msd inginition box, wires, and coil do...I mean what is the purpose and what results will i have if i add all three things to my car...thanks in advance...and suggestions of other brands will be appreciated.
Old Mar 16, 2004 | 03:41 AM
Vendetta's Avatar
hotter spark = more power
Old Mar 16, 2004 | 05:36 PM
SSmoky01's Avatar
I tell you what bro, go to www.gmhightechperformance.com and check the crane setup they did on a LT-1 Z and you will understand. No ? is a dumb ? I learn something everyday!!! Also go with a digital instead of a analog setup. There is nothing wrong with the analog BUT the digital will be better for you.
Old Mar 18, 2004 | 01:48 AM
TSAEB's Avatar
what brand do ya guys use i hear alot about msd but I was starting to look into the hi-6...any one have any opinions
Old Mar 18, 2004 | 02:24 AM
Vendetta's Avatar
I use the HI-6. Good ignition box, not as good as the MSD but lots cheaper.
Old Mar 18, 2004 | 06:45 AM
steve-d's Avatar
I too have been behind the power curve in learning what these systems do and how they work. I understand the bottom line of providing a hotter spark. But do they replace the ignition system from Opti Spark distributor to the plugs or do they "piggy back" onto the Opti spark?
Regards
Steve
Old Mar 18, 2004 | 09:48 AM
K9Kev's Avatar
Count me in on this question too.
My wife has a 93 Z and it has the terrible lag that I have now found out is common. Will the HI-6 or the MSD help with this problem?
We have done all the tune ups, plugs, wires, etc, that we can...still has a hesitation in there for some reason.
Kev
Old Mar 18, 2004 | 08:13 PM
Vendetta's Avatar
Steve- they are basically an opti piggyback. Dynaspark, ltcc, and any other ignition system you've heard of all use the stock opti, but they improve on it and eliminate many of the problems.
Kev, as for the lag, it could be one of a number of things. Check your o2s as well. If not them, try getting your PCM tuned.
Old Mar 24, 2004 | 12:42 AM
TSAEB's Avatar
well i guess Ill try the whole msd package coil, wires, box...Ill update of how it goes.
