383 lt1 ( 11.5:1)able to boost safely?
And once again sorry if what I'm saying seems dumb but if I have a car that can run a 11.4 1/4 at 475 hp. I would rilly want to push it I rilly want a 10 second car and idk if I figure it right but if I get about 580 with the weight the car sits at I can see it going 10s and I think that would be enough for me....at the moment but you always want more power.
I just don't get why u can cram a lot of boost into a low compression motor ( bring the compression high by doing this) and make good lasting reliable car but if u start off with a higher compression and add some boost ( increasing compression) why one would fail over the other. I know squeesing the air makes it hot but I figured its like already haveing some boost in it in a higher compression motor. But I have never worked on a higher compression motor before either so I'm am just learning ...I've always used a low 8.5 :1 compression motors and crammed them full of boost to get what I wanted
1. Biggest intercooler you can get
2. Meth/water injection kit
3. Boost retard ignition
4. upgrade the fuel system
Done
Or just put some dished blower pistons on it.
The OP never mentioned anything about EFFECTIVE compression ratio of boosting...just regular ole mechanically measured CR.
The typical equation used is,
CReff = CRstatic*(1 + Pb/Patm)
where CRstatic is the static compression ratio, CReff is the EFFECTIVE compression ratio, Pboost and Patm are the boost and atmospheric pressures, respectively. So for the LT1 with CRstatic = 11.4 and Pb = 8 psi (?),
There are calculators out there for this.
http://www.gtsparkplugs.com/Effectiv...ssionCalc.html
CReff = 11.4*(1 + 8/14.7) = 17.60
Anybody doing a FI build needs to do LOTS of research is the point I'm making.
You can argue semantics if you want, but I've seen it done in real life.
High boost on low compression or medium boost on medium compression can be done with the same fuel...
I just figured presure is presure...u fill a cylinder with a dencer charge it is going to make the compression higher which just game me the idea to do a low boost higher cr motor.. which would give the low end power for normal driveability and still have the great t/q curve I like.. that's why I asked here trying to get information weather good or bad...I understand and geting great info here btw that was a good read and i appriciate it.
And I'm my above post about making more cr I was talking about effective compression from what I am reading that's how I was thinking. I know the cr stays the same but the amount of pressure if what I was thinking I guess...thanks for the correction. Nick
Or build a "proper" boost motor with dished pistons to lower CR and boost the **** out of it with 12+lbs and not worry about blowing it up and make 650+ hp....and spend lots of $$$ in supporting mods to do so.
Btw the car is not mine yet I was just seeing the options for it as of now before I purchesed it.probably wait and just get a turbo ls1. But 4800 for a car I like that's already in the low 11's that just needs painted seemed like a good deal
