obd-1 and hi-stall guys
Old 02-04-2012, 04:24 PM
transbird95's Avatar
Does the "stall wall" only happen on the 1-2 shift? Could it happen on the 2-3 shift?
Old 02-05-2012, 10:45 PM
Matts94Z28's Avatar
I had this issue, I bumped my VSS up to 4500 and never had another issue.
Old 02-06-2012, 07:23 AM
moehorsepower's Avatar
For those that have no VSS parameters in their software try this, I used this when I was running a 4500 stall back in the day, On your 1-2 shift set the mph at 5mph and your desired shift at app 5400, this made mine shift at 6400, your 3-4 shift at 9mph at desired shift at app 5600, You will have to play with these points but I finally got mine to shift where I wanted it with this method...
Quick Reply: obd-1 and hi-stall guys
