26x11.50/17 et streets
Agreed. Nothing beats a 15" wheel. If you want to go DR then I'd suggest Hoosier QTP's. They hook very well.
A vette's weight transfer is far different from a f-body since it's so close to a 50/50 ratio.
Not true. They are suggested, but as long as the wheel it is mounted on is in good shape a tube is not necessary.
Village Troll
No other tire will hook other than a slick?
I figured a QTP was a DR since they are DOT approved. ET Streets work just fine without a tube for the average power levels like about 100% of the members of this forum. Weight transfer may not have anything to do with how torque hits the tire, but has everything to do with the instant load put on that tire which effects how the footprint stays true. The better the weight transfer the easier it is for load to be applied to the tire. Point being is a Vette can get away with launching on less tire/stiffer sidewall than a torque arm f-body therefore not sure why an example of a Vette is brought into this thread.
Have you ever used ET Streets without tubes?
Absolutely. I've seen them explode and kill dozens...
QTPs are not a drag radial. The weight distribution on the vette has nothing to do with how it hits the tire. And yes it is true... you NEED to run a tube in an ET Street if you want the tire to work and you want the sidewall to last. Has nothing to do with leakage, and has everything to do with using them in a torque arm f-body.
I brought up the vette example because it was an actual example of this exact tire being used in real life. Does it exactly correlate? No, but I personally think he should be on a different tire. Yes as I said I've been mid 1.4s on ET Streets without tubes, and they would have been better with tubes, way too much give in the sidewall. Please stop posting about weight distribution and weight transfer. do you realize that these are dynamic conditions VERY MUCH influenced by instant center, anti-squat, and shock settings?
Village Troll
It's a shame you did not put tubes in to prove your claim. As stated, for the average power made from most everyone in this forum, tube/no tube, it will not matter. I generated repeated 1.70 to 1.75 60' times with 26X10.5 tubeless ET Streets dead hooking with a M6 at 3750lbs and no tire spin whatsoever making average power like most everyone on here, therefore stop preaching the voodoo.
#33
#34
Village Troll
Yeah that's pretty serious not knowing a QTP is not a DR. Life or death. It's a shame you didn't catch it before Wicked did. Now, can you expound on why you'd use a slick over an ET Street or even a QTP tire?
#36
My bias ply ET streets used to be flat inside a week from 30 psi. Good quality and condition OEM rims and no punctures. Did the same thing from new till worn out.
Sicksixspeed, is your car actually a 6 speed or a 3 speed auto as your signature indicates?
If it is auto, you can try some ET street radials in 17" size.
If it is a stick shift, I would just go get some track wheels and tires in bias ply (all 4 of them). Get real slicks unless you are running in some DOT rules class.
I have a th350 in my car at the moment.
I think im gonna try these out and let yall know how it goes!
#37
#38
Village Troll
I don't usually read your posts, just make sure they aren't directed towards me. I prefer slicks because they hook better than anything else and have the longest life expectancy with competition use in my experience. Why do you prefer tires that you dreamed up from thin air?
Not sure what your "experience" is based on since the 275 DR class is in the sub 1.3 range...
Be careful if you are going to mix radials and bias ply, especially without tubes in the bias plies. My old car had some very odd handling characteristics with that combination.
Once again, since this is for the average f-body making average power like most here, there should be no concern running street radials up front and bias plys in the rear. Tube or no tube. Throngs of f-body owners have done this for years and years. If running maybe in the low 120's and up through the traps, it may be a concern.
#39
Do you know what radial means? How about bias ply, do you know what that means?
